Dewalt 18v Battery Reciprocating Saw Dc385 Type 2 Wbat Logo
Posted on Feb 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can I use a dewalt 18 volt dc9098 battery on the dc385 Saw?
Craig Becker
Level 2:
New Friend:
  • Expert 142 Answers
  • Posted on Dec 16, 2011
Craig Becker
Expert
Level 2:
New Friend:
Answers
142
Questions
Helped
75044
Points
180
If you have the handle disigned for the lithium battery becareful using the 9096 battery as it moves in the handle a lot and can hit the terminal on the switch wrong and bend it or break it. Also it will get a lot of vibration when running and because it doen't have the support that it needs for a 9096 it wiill likely brak a contact on the switch eventually. the factory does say they work in any tool however.
Repair Ahjoshe
Level 3:
  • Dewalt Master 885 Answers
  • Posted on Feb 14, 2011
Repair Ahjoshe
Dewalt Master
Level 3:
Answers
885
Questions
0
Helped
642310
Points
2112
Yes but the DeWalt DC9098 18-Volt Compact Battery will only give you 1/2 the run time of the DC9096 XRP battery.
Anonymous
Level 3:
  • Master 2,299 Answers
Anonymous
Master
Level 3:
Answers
2299
Questions
7
Helped
688881
Points
6523
You can use any dewalt battery in any drill, saw, or light as long as it fits. They made the batteries where if they will not work in a tool, they won't fit.
2helpful
2answers
How to grease dewalt dc385
The grease they recomend is part number 286436-00 at a cost of $80.87 for a 1pound can. I'd call the factory at 1-800-433-9258 and see if they offer a smaller tube.
1helpful
Saw is smoking
First I would check to two wire leads coming from the switch to the brushes. They will often melt from too much heat. There is a very good chance that the switch is bad too. Here is the parts diagram. The leads I referred to are items 43 and 44.
DeWalt DC385 diagram
2answers
How do I get a operating manual for a DeWalt DC385 Reciprocation saw
you can download the operators manual from this site
http://servicenet.dewalt.com/Products/Detail?productNumber=DC385B#
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
What other tools will the Dewalt DC9098 18v battery power?
Hi Joe,
Welcome to fixya!
Dewalt says it is compatible with all their 18v tools, except the univolt.
Please place a vote.
Thanks,
Handie Andie
I have a Dewalt DC385 Reciprocating saw, when I hold it with the blade down or level the saw will not work but when I have the blade pointed upwards it works fine. I don't think it is the trigger...
I would look at the battery contacts first for burnt/discolored contact, if so clean with something like a pencil eraser, look at the contacts on the tool also. If these are acceptable then I would think a loose wire inside the handle area is causing. Before disassembly hold tool level and GENTLY tap with a soft hammer to see if you can get it to work and that would be a first indication of a bad connection
Will a DC9098 battery fit in a DC390B 6 1/2 " circular saw?
IT DEPENDS ON THE SIZE AND LOCATION OF THE POSITIVE AND NEGATIVE METAL STRIPS
AND CLIPS ...SOME WILL FIT BUT NOT WORK BECAUSE OF THIS...DO NOT TRY UNTIL YOU HAVE CONFIRMED THIS....YOU CAN RUIN IT BY TRYING WITHOUT LOOKING.
.....I HAVE SAME PROBLEM WITH DIFFERENT DESIGN...IT WILL FIT PERFECT BUT THE STRIPS ARE DIFFERENT...................HOPE THIS HELPS.....................METALPOET
1helpful
3answers
How do i CHANGE THE SAW BLADE
Hout40, holding saw as U would use it, is a "dog" on the right side, that U pull out.
If U turn it around and look at the other end ( with the blade end) U can see the "dog" work the inside, that releases the blade. HTH, JoeB
1helpful
Cannot get saw blade to go into opening. sprayed wd40 but did no good
when you pull the yellow latch look to see it is activating mechanism sometimes it slips under it and can be a pain.........
Can I use a 18 volt XRP battery in the DeWalt DW938 Reciprocating saw?
Yes. Dewalt says the 18volt XRP battery is compatible with all Dewalt 18volt tools
Have a great day.
Top Dewalt Saws Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
