Hello, I have the following problems with my samsung galaxy s i9000: 1. When the screen is locked, and i press the home button, it takes about 10-15 seconds to show the unlock screen. When i press the home button th escreen just stays black for 10 seconds until i can unlock it with a swipe. 2. When i make a call, the screen truns black. I can't hang up etc. I tried a factory reset from recovery mode. i tried speed kernel mod, i tried lagfix. nothing solved my problems. can you help me please? i am desperate. Thank you! What i did: I Did a complete factory reset, Installed latest update of Froyo via Kies. 2.2.1 Tried everything, i don't think it's a software problem. Can it be the proximity sensor?
hi friend, i suggest you go for flash... ---------> is not the answer i was looking for i flashed it with 7 different releases, even via KIES itself. Did not help.hi friend, i suggest you go for flash... ---------> is not the answer i was looking for i flashed it with 7 different releases, even via KIES itself. Did not help.
You can't post conmments that contain an email address.
Option 1. For Galaxy S7 and earlier: Press and hold down the power and volume-down buttons simultaneously for a few seconds; For Galaxy S8 and Note 8: Press and hold down the power and Home buttons simultaneously for a few seconds.
Option 2. Go to Settings > Advantages features and enable Palm swipe to capture the screen by swiping your hand across the screen from left to right or right to left.
Option 3. Take out the S Pen from the bottom-right side of Samsung Galaxy Note 8, then press the button at the top of S Pen and use S Pen to long press the screen capture.
Press and hold the power button, then press and release the volume up button. Now you should see “Android Recovery” written on the top together with some options. By pressing the volume down button, go down the options until “Wipe data/factory reset” is selected. Press the power button to select this option
Here i provide how to unlock galaxy with hard reset. this will erase all your data from galaxy mobile.
1. Press volume up , home and power button.
2 This will provide you 6 option including hard reset wipe data. this is fourth option.
use volume down button to select wipe data factory reset and confirm it by power button.
3. this will hard reset your galaxy mobile this can unlock only screen lock.
4. when hard reset completed select reboot system now.
5. After system rebooted it will not ask for screen lock password.
if you want to sim unlock your galaxy mobile here is the guide. Howto network unlock samsung galaxy s7 edge
If you've forgotten your pattern or password lock for your Samsung Galaxy Pocket GT-25300, you may need to do a hard reset. Here's how!
Simultaneously hold down the volume up button, the Home button (the button in the center below the screen) and the Power button.
Keep holding. After a few seconds the logo Samsung Galaxy Pocket; then release the button. Check your phone boots in recovery mode. Select "wipe data / factory reset". Use the volume rocker to highlight this option and confirm the selection by pressing the Home button (in this mode, touching the screen does not work).
Select "Yes - delete all user data" in a similar manner on the following menu.Wait a few seconds while the full reset. The phone will return to the first menu.
Select "reboot system now". In a few minutes, the phone will boot normally without asking data from your account.
is its Helpful plz click on helpful
first press Up Volume Key on phone and hold it on lock screen.
then press on the home button and hold it.
Last the power button and after it starts up just release it.
A menu will come up.
just click on home button to select up and down in the menu.
go to third option named as "DELETE ALL USER DATA".
It can take up to a couple minutes.
the phone will restart and the unlock pattern problem is fixed. *note this will reset phone to factory settings, but it will allow you to access it again.
The buttons Vol Up, Home and Power are the right buttons to press. First press and hold the Volume Up and Home, then add Power. Works fine with my tablet.
PRESS AND HOLD VOLUME UP + Home Button (or VOLUME UP + DOWN)
Keep pressing these 2 buttons + press Power button for 2-3 Seconds
Release only power button, but KEEP pressing Volume up + Home Buttons (or VOL UP + DOWN)
SAMSUNG GT-I9000 GALAXY S [ HARD RESET ] FORMAT FORGETTON PATTREN SOLUTION [ TESTED ]
[1] Take out & Insert battery press & Hold VOLUME up+ Home Button Keep Power Button Pressed for 4 Seconds[important] Still KEEP Volume up & Home Button Pressed
[2] Phone will Start In RECOVERY MODE scroll down using volume down button to " wipe data/factory reset" [3] press Home button to select now scroll to "yes Delete All user Data" to confirm [4] press Home Button. Your are Done.
[IMPORTANT] Make sure you will loose all data Saved on phone memory like photos & Phone book videos ETC.
