imation super disk SD-USB-M2.Solution to run under Vista service pack 1.Works for me
boot up your puter then plug in the imation super disk into your puter's usb port then into your power sulpply socket.Then if you have a reset button on your puter Press it
the puter then shuts down and resets itself when the screen appears it asks "Start up normally" Press enter.The drive is recognised and works.Its a bit of a ball ache but works for me.Hope this helps others with the same problem
JM.
no idea if u have resolved the issue . but here is a guide . Back bottom of the phone two long screws . Under battery there is two screws one top left and one under the void sticker . Then take off the cover over the camera and there will be two more screws . slowly clip off the back case . Then this will reveal the m/board for the phone in the centre there will be a phillips screw wich releases the keypad from the front of the phone .
It is a general imate Hang up. Some imates just do it for no particular reason like a design flaw. Otherwise you could try an updated ROM version. On one imate I solved there where loose screws inside because of someone tampering with it but I don't think that's the case with yours. Try imate's site for a ROM version upgrade.
