Nikon N2000 35mm SLR Camera Logo
Posted on Feb 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What type of exposure system does it have? - Nikon N2000 35mm SLR Camera
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Nikon Master 102,366 Answers
  • Posted on Dec 27, 2011
Nikon Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10441787
Points
622693
The N2000 has Program, Program Hi, Aperture-priority, and Manual exposure modes, with exposure lock and exposure compensation capabilities. It can TTL auto and manual with flash. The meter is full-aperture and center-weighted.
The Program mode sets both the shutter speed and aperture for optimum exposure. You can adjust the exposure if you want to emphasize shutter speed or aperture. The Program Hi mode tries to set a higher shutter speed for action and/or long lenses.
You can download a copy of the manual here if you want to know more about this camera.
In my canon mf3010 printer pint like blackboard black only
Page 143 of the manual
Select the tone curve type from [No Correction], [Over Exposure], [Under Exposure], [High
Contrast], and [Invert the Negative/Positive Image].
https://www.manualslib.com/manual/1126324/Canon-I-Sensys-Mf3010.html?page=143&term=Negative&selected=1#manual
I have copier CANON PC981, when i copying theres an error coming out to displays says E2 followed by 20. and turns off automatically. how to fix this problem, thanks
Dear marlauris,
According to Canon this error is mainly due to faulty x-lamp, power supply, or exposure sensor.
As a technician I fixed this type of error by replacing exposure sensor in several similar cases. So replace exposure sensor it will solve your problem.If you have any difficulties to resolve this issue let me know.
Regards
Chandrashekhar
What type of lenses fits this camera
Lens mount Nikon F mount (with AF coupling & AF contacts)
Lens compatibility • D-type / G-type AF Nikkor (except IX-Nikkor): Autofocus and all functions possible
• PC Micro-Nikkor 85mm f/2.8D: Usable in Manual exposure mode
• AF Nikkor other than D-type (except AF Nikkor for F3AF): All functions except 3D Matrix Metering possible
• AI-P Nikkor: All functions except 3D Matrix Metering and autofocus possible
• IX-Nikkor: Cannot be used
• Non-CPU: Usable in Manual exposure mode (exposure meter cannot be used)
Electronic Rangefinder usable with lens with maximum aperture of f/5.6 or faster.
I have an error code c3300 on my kyocera 4050. How do I fix it.
Error C3300 is a CCD Automatic Gain Control issue.
It could be poor contact in the connector terminals from the SHD PWB to the CCD PWB.
It is more likely a defective exposure lamp or inverter board that powers the lamp.
Try lifting up the Document feeder so you can see the optics frame through the platen glass and turning off and then on, the main power switch to see if the green exposure lamp illuminates.
A better, but more complicated way to check the lamp is to enter the service mode and run the exposure lamp test simulation. I will outline this procedure below. BE SURE NOT TO MESS WITH OTHER THINGS IN SERVICE MODE OR YOU COULD RENDER YOUR UNIT COMPLETELY UNUSABLE.
To Enter Service Mode:
Hit the "Status" button
Hit the following sequence on the numerical keypad:
1 0 8 7 1 0 8 7
You should be in service mode.
Use U601 by typing 6 0 1 and then "Start"
U601: Turning the exposure lamps on
Description: Turns the exposure lamp on.
Purpose: To check the exposure lamp.
Display:
CCD: Main Exposure Lamp
CID: Document Processor Exposure Lamp (inside the feeder)
Method
1. Press the start key.
2. Select the item.
3. Press the start key. The selected lamp lights.
4. To turn the exposure lamp off, press the stop key.
Completion
Press the stop key. The screen for selecting a maintenance item No. is displayed.
After checking the lamp(s) operation hit "reset" a few times to back out where you can type 0 0 1 "Start" to Exit Service Mode.
1helpful
I cant get corect skin colour tone in auto white balance.i got some photographs and i see exif data of that photos in photoshop.at the exposure mode it showing manual exposure but at the scene cature type...
You can't. The Portrait mode, like all the other point&shoot modes, are automatic. The camera controls most functions, like exposure metering, auto-focus mode, and white-balance. If you want control over the camera, you'll have to use one of the PSAM modes.
Ttl auto does not work
Digital Camera Fully Compatible, Newly Developed S-TTL System "S-TTL" enables TTL auto shooting by an external strobe for a digital SLR camera as well as for a point & shoot digital camera.
INON S-TTL auto strobe supports any manufactures' model providing highly accurate exposure control.
Film camera era without strobe selection problem TTL stands for "Through The Lens" and TTL auto strobe system controls flash amount to provide correct exposure based on calculation by camera's internal sensor metering reflecting strobe light from a subject through the lens. This TTL system meters actual light amount reflecting from a subject providing accurate exposure.
When we start with the history of underwater TTL auto strobe, underwater camera?"NIKONOS V" released in 1984 was the first to provide automatic TTL flash control for underwater strobe SB-102, SB-103 succeeded by NIKONOS V compatible underwater strobes form other manufactures. The 5 pin electrical sync connector for NIKONOS V is most popular and widely adopted to connect an underwater strobe and underwater film camera (underwater camera/housing).
A film SLR camera has flexibility to select an underwater strobe. As far as housing has NIKONOS type electrical sync connector and properly wired, automatic TTL flash control is usable with any TTL auto strobe like Nikon SB-105, INON Z-220, Z-22 connected via electrical sync cable.
NIKONOS type 5 pin electrical sync connector and NIKONOS V with INON Z-22 strobe
Film camera compatible strobe is not usable for a digital camera!? Underwater TTL strobe circumstances have been drastically altered with the spread of digital camera among divers. Some underwater housing for digital SLR camera has NIKONOS type electrical 5 pin sync connector as same as film camera housing. Since the housing has same NIKONOS type sync connector, existing film camera compatible underwater strobe has been considered compatible with a digital SLR camera via 5 pin sync cable but happened to experience error message on the digital camera or blackout on an image even the strobe worked. Why this happened?
This is because automatic TTL strobe system difference between a film camera and a digital camera.
The film TTL auto system makes single flash while digital TTL auto system employs pre-flash type making two to three flashes. Film TTL auto strobe system starts firing at the same time the shutter opens and reflecting strobe light from a subject is recived at a film. The reflecting light on the film is metered by the sensor to determine when to cease firing for correct exposure. This process takes only about 1/1000 second.
In contrast, digital TTL auto strobe system can not calculate adequate exposure based on reflecting light from a subject since image sensor (CCD/CMOS) reflectivity is comparably low comparing to a film. So digital TTL strobe system gives preliminary flash for very short period of time (pre-flash) just before the shutter opens metering reflecting light from a subject by the sensor to calculate necessary amount of light for correct exposure and starts emitting main flash at the same time the shutter opens. Canon E-TTL and Nikon i-TTL employs this system.
When we connect conventional film camera compatible TTL strobe to pre-flash type digital SLR via sync cable, the strobe makes full dump by pre-flash signal then the shutter opens before the strobe has been fully charged resulting in quite under exposed image only with ambient light. Even two time flash compatible strobe like INON Z-220 strobe, does not fully support a digital TTL and force to use Manual flash mode.
Film SLR:
A strobe starts firing at the same time the shutter opens and quenches firing when correct exposure has been obtained.
A film compatible TTL strobe connected to a pre-flash type digital SLR via electrical cable flashes does not support TTL auto exposure resulting in synchronization only with first pre-flash or totally uncontrollable.
The birth of digital fully compatible S-TTL S-TTL auto compatible INON D-2000 strobe and Z-240 strobe works in TTL auto mode by simply setting their main dial to S-TTL position. A film camera seems to depend more on photographer's skill, experience and feel since the camera does not allow checking images on site. A digital camera allows us to check images right after shooting and enable to try to shoot again as much as we like. And high capacity memory card further allows to shoot hundreds of images. The digital camera makes entry level of underwater photography getting down and nowadays more people buy a digital SLR camera and underwater housing even they have just started underwater photography. However underwater photography gets more difficult because underwater strobe does not work in TTL auto.
INON is among the first to support digital TTL auto system with "S-TTL" auto mode equipped D-2000 strobe and Z-240 strobe.
The proper name of S-TTL is "Optical Synch TTL". S-TTL enables to perform in TTL auto exposure as same as genuine TTL strobe from camera manufacture, based on camera's built-in flash light to use as a signal to be transmitted to a strobe. S-TTL uses digital camera's built-in flash light not as a light source but as like a controller to trigger S-TTL strobe.
The built-in flash of a digital camera makes weak flash (pre-flash) before main-flash to calculate exposure. This pre-flash is transmitted to S-TTL strobe to control the strobe to make pre-flash to a subject. The reflecting light from the subject goes through the camera's master lens to an image sensor then a processor calculates main flash light amount for correct exposure.?Finally the built-in flash makes main-flash which is transmitted to the S-TTL strobe to cause main-flash of the S-TTL strobe.
Digital camera's built-in flash lights are transmitted via an optical fiber to the
S-TTL strobe to make pre-flash and main-flash instead of the built-in flash.
1helpful
2answers
Hi sir ....... when the copier ( kyocerammita 5530
Optical system (AGC) problem
1. insufficient exposure lamp luminosity
2. defective engine pcb
3 incorrect shading position
4. defective CCD unit
check exposure lamp harness connections; adjust position of contact glass shading plate or clean/replace the scanner home position sensor; replace the exposure lamp or inverter pcb if needed; replace CCD unit or engine/main board if applicable
Point and shoot exposure will not work; each shot requires setting exposure
Press the MENU button. Go through each screen and set them for AUTO. Also, when shooting, make sure the type of scene is set for AUTO, rather than a specific scene.
4helpful
Kyocera KM 3050 - error C3300
1 0 8 7 1 0 8 7
Display:
Method
2. Select the item.
Completion
Fun! Flash 640 camera specifications
Optics ? 7.0mm, F 3.0 (40mm: 35mm equivalent) lens ? Focal range 20" - infinity ? CMOS image sensor ? Automatic exposure system ? 1.8" color LCD display monitor ? 1/8 - 1/1000 second exposure control ? Flash range: 3-6' images ? Color: 24-bit (millions of colors) True Color ? JPEG compression ? 2 image resolution modes: 640 x 480; 320 x 240 Storage, Interfaces, and Power ? 2 MB internal memory ? Typical image storage capacity: 15 images (640 x 480); 50 images (320 x 240) ? Serial interface: RS-232 ? 4 AA-type alkaline batteries User Controls and Other Features ? Automatic self-timer ? Tripod mountable ? Automatic power saving mode Physical ? Dimension: 4.25"(l) x 1.63" (w) x 3.13" (h) ? Weight: 8 oz. (approximate without batteries)
Top Nikon Photography Experts
Tony Parsons
Tony Parsons
Pallikonda Nisha
Level 1 Expert
Are you a Nikon Photography Expert? Answer questions, earn points and help others
