Hello; You probably have a CRT type set. Something has magnetized your CRT/Picture tube. The set has a built in degaussing system that will only work when you turn on the set when it is COLD ONLY. If after several cycles of turning on the COLD set and the green color hasn't gone, the circuit in the set for doing this has failed, OR you have the set near strong magnets, such as speakers. PUT ALL speakers at least 4 feet from the set and go through these off on COLD cycles. The deflection yoke on the picture tube could have moved due to Sony using crappy adhesives to hold the yoke positioning wedges in place. I am so glad to be done with Sony!!!!! John
