You need to lean it back and remove the lower panel, you will have complete access to the water pump, disconnect hose clamps,remove and clean the rubber boot,disconnect electrical connector and 2 screws holding pump, Replace with new pump, before beginning take pictures to ensure proper installation
SOURCE: Washer Stopped Spinning
My Frigidaire front loading washer is less than 2 years old and YES there is a belt, I am going to replace my 3rd belt this week.....the wheel on the back of the drum has moved enough, even after numberous times of tightening, that it has worn a HUGE hole in the back of the drum from the belts. I will NEVER buy another product from them again, due to not standing behind their product and sending a repair man to my home to fix it, then telling me that I will have to replace the drum....(ltf2940es0).
signed
DISCUSTED WITH FRIGIDAIRE!!!!
SOURCE: Front Loader Frigidaire will not drain model no. LTF530FSO
check to make sure all hoses are not clogged - our washer hose before the pump was clogged due to washing a rug that had deteriorating rubber backing - would not drain until I flushed out the hose that goes from the tub t the pump.
SOURCE: drum wont drain
We had the same problem and the repairman found a Color Catcher sheet clogging the outlet drain inside the machine. Not covered in the warranty but after he removed it, runs like a charm. And cost us $114.00. We called the color catcher hotline and they sent us $50.00 for our problem.
SOURCE: I have a Frigidaire Crown Front loader washer,
The problem is probably the pump being clogged with an object. Typically it is a coin.
Remove the front bottom cover to access the pump. Remove the two hoses. Make sure you have a pan to catch the water from the hoses. You will be able to remove the objects after the hoses are removed.
SOURCE: My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
