SOURCE: Possible Video problem with Acer Aspire 5102.
are the fans running??
could be slight heat problem.
google for speedfan.
a utility to control fan speed on most laptops
SOURCE: Acer Aspire 5100 ; mouse freezes right after boot up
hi, yes it is a motherboard issue-i have 2 of those with same problem. new boards for that model are costly. however i found a work around-get a usb pcmcia card put it in the slot on the side-then plug your mouse or other usb devices and you should be ok! I did this a year ago and it runs like new! way cheaper than getting a new one. this is a big problem with these 5100 models. acer no help-other than selling you a new mainboard. this is the best way 2 make it work again. the pcmcia cards are cheap enough. and after that you can get a usb hub if you need more ports. good luck! and please rate this solution. and make sure 2 turn on the cardbus if not on allready. (in epower manager) this will work! reply if you need help! be well!
SOURCE: Acer Aspire 5610 freezes when loading when it starts up
assuming that u r a professional,
try open in the safe mode..press F8 rapidly/briskly while booting up..
often happens due to cpu over heating and or software corruption..check if not too dusty..
listen for any noise emitting(eg. 'tik tik' or 'kirr kirr') by the hdd..
if window opens up in safe mode..check the size of virtual memory..try increasing..
unload some unnecessary software..
do a through virus scan using a licensed and updated antivirus (i prefer avg/kaspersky)..
download, install n run microsoft kb890830..
if windows is not loading at all..reinstall os..probably ur ram/hdd is faulty or small in size..replace with a standby n see..
the above often take place with some error message(s)/blue screen..
but
if there's no such displaying, esp if hangs/stops/power off during
installation, it may b caused by the main/mother board or even the
battery..
..contact ur system admin/vendor....
SOURCE: I cannot open my Acer Aspire Timeline 5810TZ disk
This happened to me a bit too. If you uninstall the Disc Drive Power Management application, then you should be able to open the disc reader. alternatively, in the log in screen, if you press eject it should open
SOURCE: Ive had my acer aspire 6930 for about a year now
Well after contacting acer about it they told me to restore to factory settings to determine if its hardware or software malfunction.
Just sounded like a general response with the same waste of time ending.
so i bought some external speakers and a bigger sub-woofer.
Plugged them in and used the audio panel (in control Panel) to set the audio jacks to the right settings and now ive got a flourishing sound =D
Much better than the in builts, but sorry its not an actual proper solution, just another way around it.
Good news is, none of that crackling and no need to constantly pull up the audio panel to stop it.
Its a bit of money but it saves me from a pain in the ***.
