There is no battery. If the display lit up at all, the fuse is good. There is only one fuse and it is the first component on the L1 bus.
There are three door safety switches. It may be that one is bad or (as happened to me) is pluged with junk from an exploded TV dinner I set for 50 min rather than 5.
Call 1-800-659-0098 for Emerson repair.
Unless you know EXACTLY what you are doing, don't open the case, don't look for a fuse which is good anyway. The voltage of the secondary is 2100V, 2450MHz @ 1000W. Just inside the case is a capacitor that can store that energy for at least a month.
You are likely to be killed if you don;t know how to discharge that capacitor.
Battery and fuse, nonsense. Prior response was garbage.
Open it up check the battery in microwave replace check fuse replace then put back together then you should be fine.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
heatman101
