Zanussi ZWD1470W Front Load Washer / Dryer Logo
Posted on Feb 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dryer working fine but no heat coming through, displaying e72 error code
Anonymous
Level 3:
  • Zanussi Master 43,501 Answers
  • Posted on Mar 18, 2011
Anonymous
Zanussi Master
Level 3:
Answers
43501
Questions
0
Helped
10838177
Points
101584
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
What is error code F30?
The F30 code is a false code. It does not mean anything. The dryer will work fine. When I worked for Whirlpool, this was a programming issue. I owned the same dryer. It displayed this code and engineers explained this to me. The dryer worked fine.
Sep 13, 2015 • Dryers
Dryer stops running and displays E1
WHAT IS WRONG WITH YOUR DRYER?
small_8_20.jpg For a detailed Dryer illustration, click below.
redarrow.gif Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Electric dryers aren't very complicated. Here are some common symptoms that you may experience with your dryer:
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
It blows fuses or trips the circuit breaker
My clothes smell bad!
My clothes are marked or torn
2answers
Dryer codes
The error code E68 is a stuck button error code. I recommend checking each button to make sure it loose in the plastic console. The button should rock side to side a little bit. If all the buttons are loose you can try to reset the unit control by unplugging the dryer for two minutes. If the error code comes back you will need to replace the unit control.
Error codes 3 and 10
need to test with multimeter, door code error could be a faulty door switch which would hinder machine from operating. I suggest checking the glo bar and ceramic igniter for the going off problem, in electric dryers maybe in gas as well bad motor windings can cause it to go off and on?
Frigidaire front load dryer, displays E72 call service, what does this mean?
Hi Don, this is AP!
I understand you are receiving an error code of E72 on your Frigidaire dryer. Without knowing the model number specifically I can tell you the general explanation for an E72 code is an outlet control thermistor short circuit. The recommended solution is to check the resistance of the outlet control thermistor, and check wiring for a short circuit across the thermistor connections. Resistance should be between 4.9K ohms and 6.2K ohms at room temperature (68-77F or 20-25C). You may possibly need to replace the outlet control thermistor and/or wiring and retest.
However, this is not a typical DIY project. I would recommend reaching out to an experienced appliance technician just to ensure no troubleshooting step has been missed. Parts are often costly and if the problem is precisely diagnosed, it can save you a lot of time and funds.
Best of luck,
Zanussi ZWD 1270 no heat
E72 can also be caused by broken wiring to the NTC(Sensor). If the wiring is low voltage( very thin wires) then pull gently on the wires where they go into the NTC. If they break away there is the problem, you would need to replace the wiring harness for that NTC. Also, check the fan motor is running and the belt on the ventilator has nt stretched. If all is ok check the condenser is nt blocked with lint
Dryer not running, just getting a click.
check you drum belt. if belt is broken nothing will come on.
1helpful
4answers
How to get unloced nokia e72
You can get the UNLOCK CODE at here
Simpleunlocking.com
and get the Phone Unlocked from Network lock,You can follow the instructions below and unlock it step by step...
Nokia E72 Unlocking Instructions
Warning : Do not enter any wrong unlock codes on your Nokia E72 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia E72 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia E72 without any sim card.
2 - Don't bother as to what is displayed on your Nokia E72.
3 - Compose #pw+CODE+1#.
4 - The Nokia E72 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia E72 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia E72
2answers
Top Zanussi Washing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Mike Cairns
Mike Cairns
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
