RIM BlackBerry Pearl 8120 Cellular Phone Logo
Posted on Feb 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't make calls directly from my BB8120 phone book because it adds +1 infront of the numbers. This phone is a T-Mobile phone bought in US and unlocked and sent to India
Anonymous
Level 2:
Guru:
  • Expert 64 Answers
  • Posted on Feb 13, 2011
Anonymous
Expert
Level 2:
Guru:
Answers
64
Questions
0
Helped
13672
Points
186
Hi , I think to make local calls you will have to add +91+ mobile no eg: 91XXXXXXXXXX in front of the mobile no. In order to make a call to land line you will have to add the city code + land line no . eg: If you want to call Hyderabad , the no will be like 040XXXXXXXX . To make a call to mobile no in other city add 0 in front of the mobile no eg : 0XXXXXXXXXX .
tip
How do I Block a Caller on my Android Phone
<p>Here we discuss how an Android phone callers to block. These steps can be useful where you want unwanted calls directly instead of manually reject the call blocking. Follow these simple steps to block a caller making a call to the phone. Please note that the various steps may be other manufacturers like Samsung and Sony Ericsson and HTC. But the base should be almost identical. <br /> <p><br /> <p>Option 1 Steps <br /> <p>1. On the All Apps menu, click Blocked callers<br /> <p><br /> <p><span> </span>2. Click Add caller.<br /> <p><br /> <p><span> </span>3. Select from people (which are your on phone book) or just add the caller (if you remember the number).<br /> <p><br /> <p><span> </span>4. If you like people, click Save to finish.<br /> <p><br /> <p>5. If you add the caller number, click ok to finish.<br /> <p><br /> <p>Option 2 Steps <br /> <p><span> </span>1. All applications menu, click Find People. <br /> <p><br /> <p><span> </span>2. Select the caller wishes to block. <br /> <p><br /> <p><span> </span>3. Calling on the Block, "switching to. <br /> <p><br /> <p><span> </span>4. Click OK to close the. <br /> <p><br /> <p>This "Blocked Caller" function can be disabled, as shown <br /> <p><span> </span>1. All applications menu, click people blocked. <br /> <p><br /> <p><span> </span>2. Select the caller that you want to release. <br /> <p><br /> <p><span> </span>3. About Block caller, change On Off. <br /> <p><br /> <p><span> </span>4. Click OK to close. <br />
on Aug 18, 2011 • Google Android
How to block the cellphone number.pls help me
When you say block the cell phone number what exactly are you referring to? Is it to prevent a particular number from calling you or you want to hide your phone contact number? In the first case you will need to contact your service provider customer care center to provide you with a call barring code.
If you want your number hidden just add #31# infront of the number.
Hope this solution has been helpful?
I have the B3410 bought in Holland but I live in West Africa, when I don't have the Country Code of +220 in front of my phone book numbers I can not tell who my text messages are from as only the number...
Well if you are tied to a particular network all you have to do is to unlock your phone to use it any other GSM network. You can get the unlock code through online. Give your IMEI number & get the unlock code for ur mobile .............You also get through online..........I will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
18helpful
2answers
SamsungGT-S5233-A:How do i block message from a particular mobile
to block a particular mobile number, if the contact is saved in your phonebook, do these.
1. press menu,
2. select settings
3. select application settings
4. select call
5. select all calls
6. select auto reject
7. scroll down and select reject list and add number.
8. select search and it will give an option
9. select from two options, call log and phonebook
10 select phonebook (this is because the numbers were saved in your phonebook)
11, once set and configured, check and enable auto activation
12. click save and exit the settings.
if the contacts is not on your phonebook.
follow the steps 1-9 but step 10 will be your call log not the phone book.
10. select call log
11. it will give you the phone numbers of all the person who contacted you, including those who sent you a message,
12. at the right upper corner you will see all, filter it through received message and it will give you those who sent you messages.
13. select from the contacts or numbers from the list.
14, select and enable auto activation
15, select save and exit the menu
>>now you are all done.
>>no need to buy medicine for your head aches.. :-D
regards.
10helpful
4answers
Block a number calling me
1. Go to CALL LOG 2. scroll down select CALL MANAGER 3. select REJECT LIST 4. manually enter a phone number you want to block or select OPTIONS then ADD from phone book, group, or recent contacts 5. select OPTIONS to SAVE.
1helpful
I don'tknow how to block a contact on a lg arena phone
please follow the steps carefully
  1. Step 1 Call the T-Mobile customer servicemag-glass_10x10.gif phone number located on your phone bill. Tell them you would like to hear about T-Mobile's call blocking service. The customer service then tells you how you can block all the calls coming from your T-Mobile cell phone by adding this service to your plan. When you select this service, anytime you dial a number from your T-Mobile cell phone, the number will come up Restricted on the call receiver's caller ID.
  2. Step 2 Dial *67 prior to any number on your T-Mobile phone that you want to block, if you want to just block one call at a time and choose which numbers you dial are blocked. This is another way you can call someone and to have it appear as a Restricted call on the other end.
  3. Step 3 Program your T-Mobile phone to block all calls to any one individual. Do this by tapping Add a Contact on your T-Mobile phone. Type in the name of the person you want to call. Then tap Add Phone Number. Punch in *67 then the number.
  4. Step 4 Tap the person's name to call him, when you have the person's number programmed into your phone with the *67 first. Every time you tap the person's name, you will be calling him from a blocked number.
hope you dooooo...
please rate me
thank you
2answers
Ka08 sms message settings
Hello, I had the same problem, but i figured out how to get the callers id/information. On the main page select Call Center>>Call History>> SIM1(or whichever you are using)>> and select either the Missed/Dialed/Received calls. Lets choose Dialed Calls for now. Select a phone number that you recognize>>select OK>>Options>>Save to Phonebook. In here you will create a new contact. Make sure you delete this old contact information from your phone book. (so you don't have doubles if already saved to your contact list). Now you can go to your main menu again and select the phone book option. Select the contact you have created and add a photo and ring tone you like. Now when you get a call you get their photo and rign tone. For sms you get only their name, but thats good enough for me.
Talkwitch 240VS and TS400 phone
To setup the phone to automatically insert your external dial group (usually '0') before numbers, so you can save them in your phone book, and make calls from your missed / received call logs, you should check the TS400 manual.
For the TS350i you do this 1) press transfer/menu button 2) Press 4 - Call preferences menu 3) Press 8 - Access Code Prefix 4) Enter the number you use for outgoing calls (usually 0) 5) Press OK
55helpful
12answers
Blocking calls, motorola razr v3
Yes, sort of: go to Settings->Security->Enter lock code here if you've created one(otherwise ignore this step)->Limit Use->Restrict Incoming Calls From this step, you'll have to choose to restrict incoming calls from anyone NOT in your Contacts . You'll still get the voicemails and notifications of who called, but unwanted callers will go right to voicemail and you can call them back whenever you are ready.
Top RIM Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
k24674
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
