SOURCE: lens error/system error
I have successfully fixed the same error on a Nikon 2100 by dissasembling the camera and removing grit from the gears that drive the lens. However, if the camera has been dropped, I suspect that something has got dented or bent. It may be worth taking the camera apart to see if a gear has got dislodged.
I would warn you to be very careful not to get a shock off the flash capacitor inside the camera though. Also, it took me quite a while to put it all back together. It's not the easiest device to work on, a result of the very compact body (for its time!)
SOURCE: lens error on brand new G9
i got the exactly same problem!!
i bought it on 16th/Feb, next day,17/Feb not more than 20 pictures i took, the issue comes (lens won't action while shift the zoom lever, but it's working ok while switch on and off the camera)
so i bing it to the shop with my angry, they just said to me that you must dropped the camera.
--but i sware i didn't !!!
now they took the camera to Canon base for the exam...
SOURCE: lens cover stuck open
v12mike--you rock! this did indeed fix my stuck lens cover. to add on to your solution, i had the top half of the cover stuck shut and the bottom half stuck open. to get the bottom half to the shut position, i covered the lens with a little piece of paper and then used tweezers (VERY gently) to ease out the inner segment (segment 2 i think by your account), and held it in place as i reset segment 1. this did the trick!
appreciate your help immensely....cheers!
SOURCE: "Lens error, restart camera." The lens won't close,
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to corr
ect it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
SOURCE: Sammi James - number 1 spammer expert on FIXYA
Iam sorrie but try a other sd card and it will work..
