F1 on this unit means that the door latch and or the controller has failed.... you sometimes can turn the breaker off to unit and turn back on and it willl reset... most likely though it will require replaceing the control board... these units get so hot on self clean and as a servicer it is what keeps us busy.... f1 can mean three things a bad door latch mechanism, bad control board or the ribbon cable on the touch pad itself has failed and requires replacement of the touch pad... most of the time it ends up being the control itself and some of these models when you order the control it comes with a new door latch mechanism... turn power off and try that first if no cure then order parts from appliance repair or a reputable online store like
www.sears.com then hit the parts direct link up top of page and enter your model number
www.apdepot.com
www.repairclinic.com wish all the luck to you....
Hello - Before using the self-cleaning cycle of the appliance, remove the broiler pan and any utensils stored in the appliance. Also remove any excess spillovers in the oven cavity. Allow the oven to cool before cleaning. During the self-cleaning cycle, the outside of the wall oven can become very hot to the touch.
Typically to set the controls for a self-clean the first step is to confirm that the clock shows the correct time of the day. Press CLEAN. "---" appears in the display. Press the UP ARROW or DOWN ARROW once. "3:00" appears in the display for a 3 hour cycle. To change to a 2 hour cycle press DOWN ARROW"2:00" appears in the display. As soon as the controls are set, the motor drive lock will begin to close automatically and the "LOCK" indicator light will flash. DO NOT open the oven door while the light is flashing (it takes about 15 seconds for the over door to lock). "CLn" will appear in the display during the Self-Clean cycle and the "LOCK" light will glow until the Self-Cleaning cycle is complete or cancelled and the oven temperature has cooled.
When the Self-Clean cycle has completed, the time of the day or "End" will appear in the display window and the "Clean" and "LOCK" light will continue to glow. Once the over has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. If "End" is the display and the Clean indicator light remains ON, press CLEAR/OFF. The time of the day will appear in the display.
If it becomes necessary to stop or interrupt a Self-Cleaning cycle, press CLEAR/OFF. Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. Restart the Self-Clean cycle once all conditions have been corrected.
