Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on Feb 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Duet washer is making a sounds like its running, but no lights are on and door is unlocked. I've trying pushing and holding buttons to no avail
Dan Webster
Level 3:
  • Whirlpool Master 8,221 Answers
  • Posted on Feb 12, 2011
Dan Webster
Whirlpool Master
Level 3:
Answers
8221
Questions
5
Helped
2380994
Points
25840
Your tech sheet is below inside the service panel. Consult that tech sheet to see what errors are in diagnostics. Check the pump filter.
I have a manual HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
2answers
How can I unlock the door to my Whirlpool Duet washing machine?
try this link..Pull down on the bottom panel and pull it away from the washer. Reach through the open panel and up to the door lock. Find the release ring below the locking mechanism. Pull down on the ring to unlock the door.
How to Unlock a Whirlpool Duet Washing Machine ' Home Guides ' SF ...
homeguides.sfgate.com/unlock-whirlpool-duet-washing-machine-68645.html How can unlock the door to my Whirlpool Duet washing machine Google Search
6helpful
Whirlpool duet washer door will not unlock or complete the cycle
Wait at least three minutes after the end of the cycle before attempting to unlock your Whirlpool washer. The door will not unlock until the motor speed equals 0 and 180 seconds have elapsed since the motor control unit received the "Stop" command. If the water in the washer is warmer than 122 degrees Fahrenheit or the water level is set higher than Wool, Delicate or Hand Wash, the washer must drain before the door latch will unlock 2 Hold down the "Control Lock" button on your Whirlpool washer for three seconds at the end of the washing cycle. Listen, and when you hear the unlatching sound, the door should open.3 If your Whirlpool washer did not unlock at the end of Step 1, press and hold the "End of Cycle" button for five seconds to manually reset your washing machine.4 Unplug your Whirlpool washer and leave it unplugged for 45 minutes. After 45 minutes, plug your washer back in. The washer's programming should be reset and the door should open.5 Manually unlock the door of your Whirlpool washing machine. Make sure to unplug the appliance before completing the manual unlock. Use a screwdriver to remove the metal strip, called the toe panel, at the bottom of the washing machine. Once you've removed the toe panel, reach up inside the front panel of the washer and feel around for the door latch. Locate the tear-drop shaped tab at the bottom of the door latch and pull it gently. When you hear a click, the door should open.
  • 0helpful
    Whirlpool duet ht.... Door will not unlock, cancel button turns machine off. will not start, unlock button does nothing. clothes stuck inside, not sure if there is water inside or not, but will not drain...
    Hello there and thank you for chosing fixya
    Here is a few things to check before you do a manual opening of the door
    You may have already done these steps but please try this again in this order ok?
    Check to see if the "Add a Garment" light is lit on the Duet's display. The light will only be on during the first eight minutes of a washer cycle, when the function is usable.
    Press the "Pause/Cancel" button once to pause the washing cycle and unlock the door.Press the Press the "Pause/Cancel" button twice to cancel the wash cycle if the "Add a Garment" light is not illuminated. THIS IS A BIGGIE HERE (Wait for the water to drain. The door unlocks once enough water has drained to enable you to safely open the washer door NOW IF THESE STILL DO NOT WORK THEN HERE IS HOW TO MANUALLY OPEN THE DOOR
    UNPLUG THE MACHINE
    Remove the three screws securing the lower toe panel to the washing machine. The lower toe panel is the small rectangular panel underneath the washer's front door. Pull the panel off the washer once the three screws are removed.Reach up into the front panel of the washer. Feel for the teardrop-shaped tab in the washer's door latch assembly.Pull down on the tab until you hear a click. The click is the sound of the door unlocking.
    3helpful
    We have a Duet front load washer. The door is
    Hi
    Thanks for using FixYa. To resolve this issue Press and hold the END OF CYCLE SIGNAL button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    1helpful
    Whirlpool Duet Washer is LOCKED ! I need it UNLOCKED !!
    Push and hold the button that looks like a pad lock for three seconds and a beeping sound and then it should unlock. Depending on your model. Let me know.
    Whirlpool Duet makes spinning sound but drum is not spinning.
    What is the model number? To get your clothes out and the door open on that model, try unplugging it for awhile and open the door (you probably have tried that already. Some models you can take off the bottom panel and reach up and there is a little ring you can pull to open the door. (most likely) you might be hearing the pump running since it always run when spinning. If you give me the model number I can let you have the test code. You could try Pressing any key (not power or stop) hold it in for 3 seconds let go 3 seconds, press 3 sec, let go 3 sec, hold 3 sec let go. It should come up all lights on. Don't worry you can't damage anything in the test mode. Watch what it says. then press that same key about every 30 seconds to advance it. It's kind of hard to explain but I'm trying my best. It should at least unlock it in the process. Good luck
    The stays on control locked and I cannot turn it off
    usually you can push and hold the button next to the lock light. it will have a picture of a lock next to it. if you push and hold it for 5 seconds it should unlock the control board.
    Control lock light will not go off.
    Do you have any error codes?
    Does water remain in the washer after the final spin?
    If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
    Is the door locked and the Add A Garment light on?
    If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
    Is the door locked and the Add A Garment light off?
    If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
    If Pause/Cancel does not work:
    1. Unplug washer or disconnect power for one minute.
    2. Plug in washer or reconnect power.
    3. Re-select the cycle and press Start.
    NOTE: If the error remains on the display, call for service.
    Duet washer, i had water shut off to unit, and kids started it. Now water is on and it wont unlock, and runs,not turning the drum. tried unplugging, tried pushing, holding all buttons, any help?
    slect drain/spin cycle and try running that one, before it starts anycycle this achine will unlocka nd relock the door mechanism. if uyou try this what does it do??? any response???
    Whirlpool Duet
    try hitting pause cancel twice if that doesnt work turn the dial around all the way to off try to unplug the washer if all that fails the remove the three torx screws remove the lower panel and reach up where the latch is after unpluging the washer on the bottom of the latch is a tear shaped tab pull it down till it clicks that will unlock the door
    Mike Cairns
    Mike Cairns
    ZJ Limited
    ZJ Limited
