Ovens Logo
Max Puckett Posted on Feb 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Double wall oven: Model JKP26GOP13G. The upper oven heats but not up to the setting input. If setting is 350 F, for example, the stove only gets to around 200F.
Anonymous
Level 2:
Champion:
  • Expert 235 Answers
  • Posted on Feb 13, 2011
Anonymous
Expert
Level 2:
Champion:
Answers
235
Questions
Helped
75803
Points
387
I trust the door is sealed correctly. If heat is escaping this could be the problem. If the seal is okay the only thing it could be is the oven thermostat controller. It sounds like it is faulty and needs replacing.
I have a Kelvinator Renaissance double oven. I need the settings for it. Please help.
Question edited for clarity, it is a 'Kelvinator' not kalvinator. Please always include alphanumerical model number, rather the the series name.
It looks like they are called Dacor where I live.
USE ANd CARE MANUAl RENAISSANCE® WAll OvEN
Lowe's
https://pdf.lowes.com > 847364009559_use
PDF RENAISSANCE® WAll OvEN. Part No. 105488 Rev. C. For use with RO series models ... on double ovens, only the upper oven is equipped with a meat probe connector ...
Missing: kelvinator ‎' Show results with: kelvinator
Kelvinator KC900ESS User Information - Oven
ManualsLib
https://www.manualslib.com > ... > Oven > KC900ESS
View and Download Kelvinator KC900ESS user information online. Built-in Multifunction Oven. KC900ESS oven pdf manual download.
User manual Kelvinator KC9650BL (English - 18 pages)
Manua.ls
https://www.manua.ls > stoves > Kelvinator
Manual. View the manual for the Kelvinator KC9650BL here, for free. This manual comes under the category stoves and has been rated by 4 people with an ...
More here
https://www.google.com/search?q=kelvinator+renaissance+double+oven+manual
Clean between the glass on double wall oven
Unscrew the handle and screws at the bottom. Carefully separate the outer panel from the frame
Bosch double electric convection oven: top oven will heat and display code E1 15 once it gets to 350 degrees, will continue to heat with no response to temperature choosen. Set oven to 350 degrees and...
replace the oven temp sensor, it looks like a metal rod sticking out from the inside back wall inside the oven. part here....
http://www.repairclinic.com/PartDetail/Oven-Sensor/650101/1557889
Hotpoint 24in double electric wall oven 20RJ83D not heating, element is working
The thermostat for the upper element has gone bad. Needs to be replaced.
Apr 15, 2017 • Ovens
Is it dangerest when your oven beeps f2
Typically an oven beeps when the interior temperature macthes the temperature where you set the dial. This is an audible signal to that fact and particularly helpful when you need to pre-heat the oven. For example it you want to cook something at 350 degrees, you set the dial at 350. When your oven reaches that temperature it beeps to let you know. Some cooking directions tell you to preheat your oven. In that case, when you set the dial to 350 and wait for the beep...you know you are safe to start your cooking process because the oven is now pre-heated to the temperature you set. If your recipe requires a pre-heated oven, and you don't wait for the beep, your taking a guess at what temperature you're cooking your food. Additionally, if you want to know what the internal temperature of oven is and your oven is heated...you simply turn you dial setting and listen for the beep. Again, if you set your oven at 350 and you want to know how hot your oven is... slowly turn the dial setting. If the oven beeps at 275 then that's how hot your oven has gotten. To let it finish heating to 350 just reset the dial and wait for the beep.
I have a frigidaire stove that heats to 50 degrees hotter than the know setting. Can it be adjusted to read correctly?
There is a calibration method to adjust the oven thermostat plus/minus 35 degrees if it is a digital display. The method varies depending on the model range. This calibration method is used to adjust the thermostat if it is not keeping proper tempature. For example if you are setting the oven to 350 and the actual temp it is keeping is 325 then you could use the calibration method to adjust it plus 25 degrees to correct the temp. Just so you know electric ovens will keep a pretty even temp but gas ovens will vary by 40 or more degrees to keep an "average" temp. For example the burner will come on when the oven is 330 degrees and turn off at 370. 330+370 then divide by 2=350. So a oven thermometer may not show you the temp you set it at in a gas oven but does not mean the oven temp is off.
Jan 14, 2010 • Ovens
My HBL452 double oven is slow to heat both upper
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
GE Profile JT952 Double Wall Oven doesn't heat up adequately
heatman101
2answers
I have a double gas oven and no instructions
I have an O'Keefe & Merritt double oven gas stove. The model number is 72 7242 23. The upper oven is about the size of a large microwave and sits above the range burners. The lower (full-size) oven is below the burner unit and includes a broiler draw below it.
So, when you say, double oven, I wonder if you are just talking about the main oven with broiler drawer (both of which are below the burner unit.)
Mine was a builder-supplied appliance in the new house we purchased in 1986. The upper oven has never performed very well. And, yes the upper oven can only be used for baking.
I have an instruction manual for it, but it doesn't provide that much information. Getting parts for it is extremely difficult, since Tappan is no longer manufacturing this brand. (I've been trying to locate a flat oven ignitor for the upper oven and can't seem to find a replacement that's the same 6-1/3" length.) In the 1980s Tappan apparently purchased O'Keefe & Merritt and marketed this brand for several years. Models originally manufactured by O'Keefe & Merritt in the 1930s-1950s are considered collectible antique stoves!
If you want to email me, I'm at [email protected]
Top GE Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a GE Oven Expert? Answer questions, earn points and help others
