Firstly turn the power off. Lift the cooktop out from the benchtop and lean it against the wall. There will be a small panel where the wiring terminates into the cooktop. Remove the panel and disconnect the wiring to the cooktop. Ensure that you insulate all wires properly. You can then turn the power back on if you need to.
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
