This is probably the solution:
http://www.fixya.com/support/t2074406-wont_pictures_flash
Wont take pictures with flash
Dear sir,
It seems ur battery is weak , since it use AA battery put new alkaline batteries & then try .. I beleive it will take pictures with snap .
Regards
[email protected]
I was skeptical about this fix at first, but as per Mary's solution, I removed the 6 screws to the housing, eased the back and front plastic off, removed the plastic flash assembly shield screw.There, above the screen, you'll find a green and white ribbon cable.I carefully pushed them back into their seats and voila! The flash that used to only give me a blinking lightning bolt now works again after a 10 minute fix.Thank you!
The problem is in the battery holder of the CR1220
battery.
-Take out the CR1220 battery (the little round one).
-When
you replace it, put a bit of aluminum foil against the back, between the
battery and the plastic holder, to make it a nice tight fit. One layer won't do
it, but don't put in half the roll.
-Put it
back in. Done
Using a
fresh battery & clean it all with alcohol = good idea as well. Worked for me.
Wich
