Since you declined to specify the model of your Uniden cordless system I can only suggest you select it from the list beginning here to download a copy of the manual.
SOURCE: i lost my manual on Uniden dect1580 phone. it's
please download your manual here in the list: http://telephones.att.com/telephones_ui/support/dsp_manuals_list.cfm
SOURCE: Problem with the Uniden DECT
You can download the manual from the manufacturer's web site at
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1363om.pdf
SOURCE: Uniden Dect1560 - For incoming
Your model is a phone only, without an answering machine built in. This means that voicemail is provided by your phone service on your line, and that's where you need to adjust the rings before it picks up. The phone itself has nothing to do with it.
You may have to call your service provider for setup instructions because not all systems are the same, but here's how it usually works. Pick up your phone and call your own number to reach your voicemail. When your message starts, press the * button and the system will ask for your pass code (just like when you call to get your messages). Follow the voice prompts to reach the main menu, then mailbox settings, where you'll be able to change the ring count.
If these steps don't work for you, ask your service provider what you need to do.
Testimonial: "Thank you. Great answer."
SOURCE: How do I change the number of rings before voice
I already have encountered several of these concerns but the number of rings before voicemail activates is not a setting that can be adjusted on the phone. It depends on the Telephone Service Provider. According to them, they cannot adjust it. That's how it works and there is nothing they can do about it.
SOURCE: How do you change the number of rings before the
That depends on the model of your system. Select the model from the list beginning at
http://www.uniden.com/owners-manuals/dect-phones/scat/dectphones_mnl/
to get the appropriate manual.
