Have you tried inserting other game discs? like 3 types of disc. If your Wii console plays those discs and don't play with the game disc that you wanted to play, then the format of that disc is not recognized by console. Some disc formats are sometimes incompatible with the player console.
If you are getting one of the above error messages:
This message can display if you eject a disc during game
play. If this is when the message displayed, make sure that you return
to the Wii Menu before changing discs if you wish to play a different
game.
If your Wii console is laying flat, it may be positioned
upside down. Ensure that is positioned right-side up: the game disc slot
should be above all three buttons and the SD Card slot.
Ensure that you are properly loading a Game Disc.
If your console is placed vertically, the disc label will face to
the right.
If your console is placed horizontally, the disc label will face
upwards
If you know you are inserting the Game Disc correctly, but
are still have the same problem with only one game (or if you only have
one game), try cleaning the Game Disc by following the disc cleaning
procedures (click here).
If the above information did not resolve the issue or it is happening
with most or all of your games, a repair is necessary. Please note: So that
our technicians are able to duplicate the issue, please include at
least one sample game disc that causes this message to appear when
played. Click
here to set up a repair.
This can be caused by a dirty laser in the drive. Try cleaning the laser with a q-tip and alcohol. If this does not fix the problem, the laser may need to be replaced. Contact Nintendo and see if the unit is still under warranty.
If Wii gives Disc Read Error, first step you need to check is to try another
disc or clean the exisitng disc. This will confirm that problem is with either
Wii or Disc. If the console itself is giving disc read error then it needs to be
repaired. You may check out DIY Wii Fix Guide, that
will show step by step information to fix the problem yourself. It also gives
information on fixing many Wii Related Problems, so its a kind of Wii Problems
Reference Fix Guide..
Reference Fix Guide
If Wii gives Unreadable disc, first step you need to check is to try
another disc or clean the exisitng disc. This will confirm that problem
is with either Wii or Disc. If the console itself is giving disc read
error then it needs to be repaired. You may check out DIY Wii Fix Guide,
that will show step by step information to fix the problem yourself. It
also gives information on fixing many Wii Related Problems, so its a
kind of Wii Problems Reference Fix Guide
"Unable to read the disc" / "Disc could not be read" / "Eject the Game Disc" Error Message.
If your console is placed vertically, the disc label will face to the right.
If your console is placed horizontally, the disc label will face upwards
If you know you are inserting the Game Disc correctly, but are still have the same problem with only one game (or if you only have one game), try cleaning the Game Disc by following the disc cleaning procedures
If after reading the above information you are still unable to play a game disc, please call 1-800-255-3700 to discuss available options.
