Canon NP 7130 Black and White Copier Logo
Posted on Jul 23, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
An orange light blinking
I have an orange light that blink between the paper select and the number display. I cannot make out what the pic is. Could it be that the toner needs to be replaced?
After turning it on and making copies it stays running like a fan noise for a short bit then it quits making the noise and the light blinks. and in order to make any more copies you hae to turn it off and on again. I do not have a user manual. Thanks
Pastor James Shelton
  • JimShelt66 Jul 24, 2008
    The orange light illuminates a symbol. The symbol is this.
    It is an arrow pointing downward and is pointing to one circle that is on top of two circles which is on top of three circles. Then this is enclosed in a square with the exception that the top of the square is open. Don't know if this will help anyone figure what my copier is trying to tell me or not. But your answer is greatly appreciated. You can email me the answer if you wish @ [email protected]
    Thank you so much for your help and your quick responce. I will replace the toner. Once again I appreciate it very much.
Lance Farrell
Level 2:
Habit-Forming:
  • Expert 50 Answers
  • Posted on Jul 24, 2008
Lance Farrell
Expert
Level 2:
Habit-Forming:
Answers
50
Questions
0
Helped
53197
Points
133
You are absolutly right. It needs toner. That symbol is the universal symbol for toner. ( dont ask me how they came up with that but its true.)
The reason the copier runs on when you turn it off and on is because it thinks you may have added toner and is trying to auger toner out of the cartridge into the machine. After a time it gives up and assumes the cartridge is empty..
What does the orange light mean blinks
What is the brand name to your TV? I assumes that, it may be a DLP projection TV. Provide more details please. If you wish to get some details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Timeslide / Flipcard, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
Blinking codes and possible defective boards to many popular brand TVs are given in detail.
Samsung 32 lcd red light flashes 4 times
Denotes a problem to its main power supply regulator board. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
These blinks of standby light are called Blinking codes. Details to many brand TVs are given.
2answers
Problem with canon ip3300 orange light 5 time is blinking
Hello!
Orange light blinking show your printer has a problem and the error will display on your printer LCD. So check the error number on your LCD and send me the error number correctly. thanks
I can't print and I have an orange flashing light on the right side of the printer. Whay does this mean?
Issue: The Power light is on and the Resume light blinks
In this error condition, the following light pattern displays on the product control panel:
•Print Cartridge status light : Off
•Resume light : Blinking (orange)
•Power light : On (green)
Causes
??¦The product is processing a print job, or waiting for the ink to dry on a document.
??¦The product might be out of paper.
??¦The product might have a paper feeding issue or a paper jam.
There are several possible solutions. To work through these suggest you follow the illustrated on-line guide found here.
The orange warning light flashing what can i do to stop it?
check for paper jam if any or p head or cartridge indication for replacement
some symbol my blinking in display for user attention
this also indicate for error in plotter check for display icon and if you find any special icon other than normal screen as earlier, it will give information like paper with X mark ( no paper in tray )or paper jam ( two circle with Z mark )
or may be some screw driver and spanner X mark that can decode to give reason for LED blinking
if you get tool X mark check for ink level box in each row to check error code, its would be 6 numbers of rows and each row may some box
need to check and confirm to verify the error code
1helpful
ORANGE LIGHT BLINKS TWICE
2 blinking means "No Paper"or "No Paper in tray"
3helpful
Cannon i960 blinks 1 green , 3 yellow etc... Won't print sayas pa
Canon i850, i950, S600
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. release RESUME
3. press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
If I could be of furtheme know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
1helpful
Paper Light Blinking
make sure the rear part of your paper tray is not pressed too tightly against rear of paper. it will prevent the paper from raising up fully to the feed roller. you can also try cleaning the feed roller if that doesn't do it.
hth,
razors
5helpful
5answers
Phillips FTR 9964 Blinking Green/Orange Indicator Light
PHILIPS 42 WILL NOT TURN ON,WITHE FTR9964 RECEIVER
TO BLINK ORANG /GREEN AFTER 40 SEC ORANAGE
old marine
old marine
ZJ Limited
ZJ Limited
