tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light. Ple help me
The probable cause is with its main board. Not probable, it is. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. http://electronicshelponline.blogspot.com/
Your tv set may have an overload in the supply line. Check its rectifier diode and filter capacitor. Another approach is to check if the DC supply line of the switch mode controller IC (UC4842 for exemple).is present (10/12V). If these are OK, replace the switching MOSFET transistor and check the source resitor for open circuit.
i have the same problem. i just replace the power board because of the "green blinking" light. now, light stays green, picture comes on for a few seconds, then blank....
hi you might have to contact the place where you bout the tv an let them kno your problem if they cant help you then call sharp and let them know your problem your tv is covered for one year so if you had your tv less than a year let them know that also
