How can I find software for my Olympus AS-2300 PC Transcription Kit for windows 7 as well as Mac version. Olympus is not providing the software on their site.
I saw the AS2400 is compatible with Windows XP/2000/Vista.
You can install Windows XP in your computer (I presume you have a 4th Gen Intel processor installed in it) and run this software under Windows XP.
On the Windows 8.1 Help and Support, search: Windows XP
If you have a 64 bit version of Windows 7, you will need an RS27 foot pedal. The RS23 and RS25 are not supported. RS27 is available at dictationmall.com
The AS2300 foot pedal RS23 or RS25 are not compatible with 64 bit operating systems. You will need an RS27 pedal, available at http://www.dictationmall.com/147-035.html
HTML clipboard
Olympus AS-2000 is not Vista compatible, you need to upgrade your software,
I am not sure which version you have, but I think its version 6 ? You need
to upgrade your software from version 6 to 7 (free) and then from
version 7 to Standard (also free ) . check your foot pedal if it's RS-23 (
check the back of it ) then you need a new foot pedal ( RS-25 or RS-27 ) , if
you have the RS-25 or RS27 you are ok .
http://www.olympusamerica.com/cpg_section/software_results.asp?id=1219&os=w
The answer is all in the serial number you use to install the DSS player!
Look carefully and you will see the recorder disk has in my case an [E] printed above the install serial number and the transcription pedal has [T]
Install the same disk with the E the driver is there, the control in Control Panel is there, but the foot switch does not work with the software. Put in the serial number with the [T] and foot switch works first time!
If you uninstall the play and then reinstall with the [T] serial number you do not need to reboot or even unplug the foot switch from the USB.
