Learn why is a pc running slow and how you can fix the issues from: http://www.whyismypcsoslow.net/
Corrupted System Files
Your computer slows due to corruptedsystem files. System files corruption is one of the most responsible causes forcrashing the entire computer. Deleting or moving the system files may crashyour computer.
1. Insert the Microsoft Windows Installation CD ROM.
2. Click Start ' Run.
3. Type SFC/ ScanNow and press ENTER.
4. Follow the instructions on your screen.
Corrupted Registry
System registry corruption leads to runtime errors and your computer slows.Windows Registry is very complex and not easy to repair manually. Hence, athird-party Registry Cleaner and PC Optimizer software is recommended.
1. Download a Registry Cleaner and PC Optimizer software such as Reginout.
2. Click Registry Cleaner tab.
3. Click Start Scan.
4. The registry scan will start. Wait till it is finished.
5. As per the results, click Fix Now button to start repairing you registry.
Often good registry cleaners include built-in Backup & Restore centre thatlets you recover from an unforeseen situation by simply restoring the state ofyour registry.
Faulty RAM
Your computer crashes due to problems with the computer memory. A faulty RAMmay result in Blue Screen of Death (BSOD).
In such a case, remove the existing RAM and clean it using a soft cloth. Then,connect it again. The problem may not persist..
Incomplete Installations
Your computer slows because of apreviously failed or incomplete installation. An incomplete or failedinstallation creates junk registry entries and thereby system crashing problem.
Repair the registry entries created by a failed setup and delete the files thatstill remain on your hard disk. Delete the contents of C:\Windows\Temp folder.
Disk Space Allocated by Unnecessary Files
Your computer slows if the operating system has no adequate free disk space toperform its operations. Temporary files, temporary internet files, log files,browser cache and other files may occupy a large amount of your disk space andthus generating runtime errors that crashes your system.
Using Disk Cleaner, delete the junk files from your hard disk. The steps are asbelow:
1. Click Start ' All Programs ' Accessories ' System Tools ' Disk CleanUp.
2. Follow the instructions on your screen.
Clean
Windows Registry : Defragment
your PC to increase computer speed: Add more
RAM to Speed up your computer Clear Cache,
history and temporary internet files Turn off
unnecessary programs from start up: Have low
intensity graphics Uninstall
unused software and programs Please remember to clean Windows registry
using registry cleaner reg in out The
above guidelines were really helpful to speed up my computer. These are safe
and do impact computer performance in a positive way. Repair
and Clean Corrupted Registry using reg
in out Install
the latest.Net framework Stay
logged-in to the Download Manager Reinstall
Download Manager After Uninstalling it Fix Dll
Errors usinf reg in out and Update
Microsoft Direct-X
