SOURCE: philips shaver not charging
The batteries are soldered to the circuit board with solder tabs. These are not standard chargeable batteries that can be bought at the corner hardware store. The are Lithium Oxide based batteries with solder tabs. These should be replaced by an experienced tech. The replacement batteries must be to spec of the original ones. There is the current rating and voltage rating of the batteries to matched.
Because these chargeable batteries can put out a strong amount of current, if they are not installed properly, there can be safety issues.
Call Philips tech support to be advised about where you can take the shaver to have the batteries changed.
Jerry G.
SOURCE: Shaver head warning light
Here is a link to the owners manual for the HQ7785 Electric Shaver. If
this is the wrong model, your manual may be listed at this site as
well.
http://personalcare.owneriq.net/manuals/mfg/philips/hq7740.html
SOURCE: I lost my Philips Coolskin 7775X shaver charger.
Hi, You can purchase a new charging cord from electricshaver.com for around $23.00 which is probably the best thing to do if you want to keep using the shaver.
Otherwise the specs for the shaver are as follows:
The part number for the replacement charging adpater cord is #3605160
Here's a link to the part you're looking for, should you decide to purchase a replacement instead of trying to make your own charger, which will be difficult unless you have the full array of electrical components and ability to fabricate it.
http://www.electricshaverstore.com/get_list_144.htm
You can also give them a call at 1-888-476-1785
Hope you find this Very Helpful and best regards!
SOURCE: philshave coolskin HQ7762 battery type ?
This model is rechargeable and has internal batteries. You will find replacement battery pack at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-battery-pack-for-most-norelco-more-p-278.html
SOURCE: My philipshave coolskin shaver doesn't
Your battery pack is probably dead and needs replacing. You will find the correct battery for model 5605X at shaveroutlet.com. See link below for item and also scroll down item page for installation tip videos
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
