Panasonic HDC-SD5 Flash Media Camcorder Logo
Posted on Jul 23, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
DVD Copy Hi, I have a Panasonic -SD5 camcorder. I am using HD writer to copy files from SD card to computer. How do i transfer the images to a dvd or play it from teh computer? Thanks
  • 3 more comments
  • skhodadin Jul 23, 2008
    Hi is there no way I can transfer the recorded video to DVD?
  • Anonymous Dec 26, 2008
    How to copy files from SD card to computer. How do i transfer the images to a dvd or play it from a computer using HD writer. Thanks
  • gyorgy petocz Dec 26, 2008
    How to copy files from SD card to computer. How do i transfer the images to a dvd or play it from a computer using HD writer. I foowed the instructions of the manual but got the ,essage "media status lock". Thanks
  • c1960 Dec 31, 2008
    i hav jvc my prob is copy the cam to dvd
  • Anonymous Mar 24, 2014
    I am trying to copy video taken with a Panasonic HDC-SD40 from the SD card to DVD.
alexander sakelliou
Level 2:
  • Expert 95 Answers
  • Posted on Jul 23, 2008
alexander sakelliou
Expert
Level 2:
Answers
95
Questions
0
Helped
26669
Points
111
Hi, you are going to need a high def player to view or play this info:
Nanny
Level 3:
Genius:
  • Panasonic Master 2,351 Answers
  • Posted on Nov 14, 2019
Nanny
Panasonic Master
Level 3:
Genius:
Answers
2351
Questions
0
Helped
988837
Points
7262
Leawo DVD Creator is created and constantly improved to facilitate users in burning camcorder videos to DVD professionally and practically. It offers abundant menu templates for users to use and powerful editing features to make their videos perfect for burning.
I have a camcorder Panasonic SDR-T55 and want to copy my pictures from built in memory into sd card but I don't know . Please help
You may not have that option.Most camcorders give you the option to either record to the built in memory or the SD card Flash Memory.The option to copy from the internal to SD card is device option. You can use USB, AV , cables to convert files to DVD or other formats to copy to Flash Media or DVD/ VCD/DVD RAM.Good Luck.
2answers
Sound loss through conversion to MPEG
HI,
It can be the software problem.I'll give you another software conversion tool to mpeg.
Goodluck..
2answers
Error reading uploaded video using HD Writer
try this converter: http://avs4you.com/AVS-Video-Converter.aspx?type=GoogleAdWordsSearch&gclid=CPzqs8yy6JcCFQEpGgodvyWzDA
HD writer will not write to disc
I just used HDWriter today to copy a film I took from a new Panasonic HDC-HS250K to DVD. It took about 30 minutes to complete, and the movie was only 1 Gb; about 5-10 minutes of HD. I used a Memorex DVD+R that I happen to have from a couple years ago. The video looks very good played back on my PC or HD TV using a regular DVD player (not blue ray). I don't happen to have any other DVD except for the 2 sided which I hate to use for the short videos. So in looking to buy some more I'm concerned that DVD-R might not work so well. I've read some conflicting reviews about that. Anyway just wanted to let you know that the DVD+R worked fine.
Panasonic sd20 takes 4 hours to burn 10 mins of video to dvd-r/+rw using hd writer 1.0 computer is hp pavilion 3726
convert video and then burn using this program: http://avs4you.com/AVS-Video-Converter.aspx?type=GoogleAdWordsSearch&gclid=CPzqs8yy6JcCFQEpGgodvyWzDA
9helpful
6answers
Unable to use Easy Editing function on HD Writer 2.0E for sx/sd
Did have the same problem. If you have copied (backuped) the files to your harddrive, you must have twice the amount of free space available (working-area) on your HD to be able to edit the videos with the panasonic software. Default the workarea is c:\ (choose settings in main menu --> HDD Settings --> Select working area) After changing it to the d-drive (80 gb available) i didn't get the message and could working again with the video's!
2answers
Conversion from AVCHD to MPGEG with Panasonic HD WRITER
The video formats that your Panasonic HD-SD5 produces is AVCHD format, you you can choose an AVCHD video converter to help you to convert AVCHD to MPEG.
The most easiest and fastest video converter i ever used is Aunsoft MTS Converter which can hel you to convert MTS video files to almost any video format you need.
If your want to join your sapareted video files into one, this software can give you a hand due to its function of merjing video files into one.
http://www.aunsoft.com/mts-converter/
2helpful
2answers
Hd writer 2.0E fro sx/sd
I had this same issue...I bet you're using DVD-R, am I correct?
Apparently you can't copy video from DVD-R to the HD Writer. Period. Just can't do it. (Would be nice if they mentioned this in the manual.)
You can only use DVD-RW and must format the disc to VR format, not Video format.
I'm using a program called Handbrake (free) which I think can convert your .vob files (from the Video_TS folder on your DVD) to quicktime files, or similar, so that you can actually do something with the video...
Best of luck, I'm really no expert, and I probably won't return to this page, so a reply to me is likely not going to be read by me...
2answers
How do I copy the files to my computer?
• Windows XP After connection is established, simply drag-and-drop files, using Windows the PC. The DVD Camcorder appears as an external DVD-RAM drive in Windows • Windows 98SE, ME, 2000 After connection is established, simply drag-and-drop files, using Windows PC. The DVD Camcorder appears as two external drives such as a removable Explorer. If DVD-RAM disc, the movie files will be copied from the removable If DVD-R disc, the movie files will be copied from the DVD drive.
Top Panasonic Video Cameras Experts
NOEL
NOEL
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
