ASUS M4N68TM Motherboard Logo
A
Anonymous Posted on Feb 11, 2011
Just got a Asus m4n68tm motherboard 250 processor 2gig ram to go with a half gig hd and a 450w psu. Assembled everything nicely and fired the thing up only to find - no video. Everything seems ok but just no picture. Tried 2 different screens but nothing. Any advice?
Anonymous
Level 2:
New Friend:
  • Expert 139 Answers
  • Posted on Feb 11, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
139
Questions
Helped
16979
Points
411
Try removing you ram and putting it back in make sure it locks in place, and make sure your cpu installed correctly and securely. Also try clearing the bios. If this does not work reply back to this posting with you complete configuration make and model of every thing.
1 LONG BEEP, 2 SHORT BEEP
1 long, 2 short Failure in video system: a checksum error was encountered in video BIOS ROM, or a horizontal retrace failure has been encountered
1 long beep, 2 short beep
You have a bad RAM, install just 1 module and try, is doesn't swap the memory module and try again.
http://www.gigabyte.com/support-downloads/faq-page.aspx?fid=816
3answers
My asus m2n32-sli motherboard won't start up; runs for 4 seconds then shuts off. currently hooked up to the mobo: have a 500W power supply; AMD 3300 64 processor; zalman cpu fan; 2 patriot 2GB DDR2...
The only thing i can suggest is remove one of your RAM sticks and see if the machine will boot. I had this problem with mine and it turned out that one of my RAM slots was faulty and would not boot if both RAM slots had RAM in them.
ASUS P4P2E-X 1 long beep that continue without end
hi,
I think One long beep that continue means RAM problem , Ram Can May be dead or faulty, check on other ram.
I hope that this has been very helpful for you
I have 1 gig ram added 2gig of ram to my P5VDC-MX mother board.
Your system might only be able to recognise 2gb of RAM. Tiger Direct has a RAM finder for almost every computer. Check it out to see if you have too much.
2helpful
Asus K8U-X motherboard,which ram memory , and processor support?
hi..for this mother board model asus K8U-X only same brand Processor u can oly use.Like if u use Sempron made by AMD only AMD Processor for that board.Memory support is DDR1 PC400 1gig up to 2gig...good luck and Have a Nice Day..
Advice for buying a new power supply compatible with my videocard
Get a 600 watt they are better and will handle all that you need the price from a 450 W to 600W is not much I run 7 dvd's a ATI Video capture card with a 64 bit AMD processors 1 80 gig Hd 2 Sata Drives 120 gig and sound blaster audio card and more and the 600 watt does fine The Corsair is ok Where to you think your going to get it at on line? or at a store? You can buy them at
tiger direct.com or Fry's.com The 600 watt ATI power supply will have 6 standard HD connecotors and I use three Y's for more and never had any problem with mine.
Replacement Motherboard (ASUS) P4S533
try using a bare system only means motherboard, psu, processor, ram then connect a speaker, does it make any sound ?
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
