Question about Nostalgia Electrics CCP-509 Popcorn Maker
Need to replace bulb what kind and size do I need
    Genius:
  • 1,739 Answers
The replacement is an E27 40 watts light bulb. For future reference the User Manual for your Nostalgia Electrics CCP-509 Popcorn Maker can be found here:
http://nostalgiaelectrics.com/manuals/ccp-509.pdf
Posted on Mar 25, 2011
6ya staff
SOURCE:
What size or what kind of light do i need for my chevy impala 03'the back white light is out, not the red light ANSWER ASAP
It is called a 'reversing light'.
Reverse Light Replacement 2000-2005 Chevrolet Impala - 2001 ...
https://www.carcarekiosk.com/video/2001_Chevrolet_Impala.../lights/reverse_light
The reverse light is the white light that lights up when your Impala is in reverse. The video above shows you how to change the reverse light in your 2001 Chevrolet Impala. These bulbs burn out occasionally and help you see when you are backing up. The reverse light gets dimmer over time and we suggest changing them ...
How to Replace Backup Lights on a 2003 Impala ' It Still Runs ' Your ...
https://itstillruns.com > Maintenance The backup lamps on your 2003 Chevrolet Impala are located in the applique on the rear of the trunk lid. The backup lamp replacement process involves removing the applique to access the bulbs. The entire process is relatively simple and straightforward and only requires the use of a socket wrench and a replacement ...
Chevrolet Impala Back-Up Light Mini Bulb - AutoZone
https://www.autozone.com > ... > Chevrolet Impala Headlights And Exterior Bulbs Chevrolet Impala Headlights And Exterior Bulbs. ... Vehicle Specific Sylvania Back-Up Light Mini Bulb. ... Vehicle Specific SilverStar Back-Up Light Mini Bulb.
2003 Chevrolet Impala Car Lightbulb Size Diagram - Modified Life
www.modifiedlife.com/2003-chevrolet-impala-car-lightbulb-size-diagram/ When you need to replace the headlight, turning signal or parking light bulb on your 2003 Chevrolet Impala, finding out what the replacement size you need can be a time consuming task. Whether you want to replace your headlamp bulb with a HID (High Intensity Discharge) Headlight Kit, Xenon Headlamp Kit or replace ...
Pictures in the link
2003 impala reverse light bulb Google Search
Dec 04, 2017 | Cars & Trucks
How do replace driver side headlight bulb? What size do I get?
Go to your local auto parts store.Ask at the counter,give them your make and model and year.
High & Low Beam Headlamp Light Bulb Size: 9007
Parking Light Bulb Size: 194NA
Front Turn Signal Light Bulb Size: 7507 Or 2827
Rear Turn Signal Light Bulb Size: 7507
Tail Light Bulb Size: 7443
Stop Light Bulb Size: 7443
High Mount Stop Light Bulb Size: 7506
License Plate Light Bulb Size: 168
Back Up Light Bulb Size: 921
Front Side Marker Light Bulb Size: 194NA
Rear Sidemarker Light Bulb Size: 7443
Dome Light Bulb Size: DE3175
Trunk/Cargo Area Light Bulb Size: DE3022
The bulb is in a socket which will twist out,then there may be a clip that holds the bulb in.
Jun 25, 2011 | 2003 Mitsubishi Lancer
How do i change the brake light on jeep liberty 2006?
1) You will need to open the rear swing door.
2) On the inside jam there are two torx headed screws (T-15's if I remember correctly).
3) Unscrew the two torx screws.
4) The light is now held by two mounting tabs (small spherical headed plastic sets that go through a rubber grommet).
5) You will need to pry the light casing off (easy pressure with a good size flat head screw driver will do the trick).
6) The light bulbs are twist mount settings inside the light casing.
7) Twist out the mount setting, change the bulbs, and reset the light mountings.
8) To put the light casing push the light casing back on and put in the screws. Everything else will work in reverse when it comes to assembling the whole unit.
2006 Jeep Liberty Replacement Light Bulb Sizes
Low Beam Headlamp Bulb Size: 9007
High Beam Headlamp Bulb Size: 9007
Parking Light Bulb Size: 2825 or 3157
Front Turn Signal Light Bulb Size: 3157
Rear Turn Signal Light Bulb Size: 3757ALL
Tail Light Bulb Size: 3157
Stop Light Bulb Size: 3157
High Mount Stop Light Bulb Size: 921
Fog/Driving Light Bulb Size: 9145 or H3-55W
Back Up Light Bulb Size: 3157
Front Side Marker Light Bulb Size: 168
Ash Tray Light Bulb Size: 161
Map Light Bulb Size: 578
Dome Light Bulb Size: 578
Step/Courtesy Light Bulb Size: 906
Trunk/Cargo Area Light Bulb Size: 578
Thank you for using fixya, and good luck
May 08, 2010 | 2006 Jeep Liberty
2000 pontiac montana. I want to replace the driving ligh bulbs. the under the headlights what size is it?
Fog/Driving Light Bulb Size: 880
Here is the rest of the bulb size used in your Montana.
2000 Pontiac Montana Auto Light Bulb Diagram
Low Beam Headlight Bulb Size: 9004
High Beam Headlamp Light Bulb Size: 9004
Parking Light Bulb Size: 4157NALL
Front Turn Signal Light Bulb Size: 4157NALL
Rear Turn Signal Light Bulb Size: 3156
Tail Light Bulb Size: 3057
Stop Light Bulb Size: 3057
High Mount Stop Light Bulb Size: Assembly
Back Up Light Bulb Size: 3156
Front Sidemarker Light Bulb Size: 194
Ash Tray Light Bulb Size: 558
Glove Box Light Bulb Size: 194
Map Light Bulb Size: 168
Dome Light Bulb Size: 562
Step/Courtesy Light Bulb Size: 168
Trunk/Cargo Area Light Bulb Size: 212-2
Daytime Running Light Bulb Size: 3157NALL
Thank you for using fixya.
Apr 30, 2010 | 2000 Pontiac Montana
2001 LeSabre - replace rear license light. The rear license plate lights do not light up the license at night. How do you get to them? What size bulb do you need?
kind of tricky, took me an hour to get it figured out, but you got to open the trunk and take out the 10 or so 10mm nuts sticking out of the backside of the lid, then the whole solid piece where the lights are on the back will slide off, then you can change the bulbs above the license plate and put it all back together, im cant remember off hand the bulb size, but your local auto parts store will have that info when you go to buy them
Mar 05, 2010 | 2001 Buick LeSabre
I have a 2000 Mountaineer. The front parking lamps are missing along with the bulbs. Does anyone know what exact bulb is needed to replace these? Many thanks
2000 Mercury Mountaineer Auto Light Bulb Size Guide
High Beam Headlamp Light Bulb Size: 9007
Parking Light Bulb Size: 3157NALL or 3457ALL
Front Turn Signal Light Bulb Size: 3157NALL or 3457ALL
Rear Turn Signal Light Bulb Size: 3156LL
Tail Light Bulb Size: 3157LL
Stop Light Bulb Size: 3157LL
High Mount Stop Light Bulb Size: 922
Fog/Driving Light Bulb Size: 9006
Back Up Light Bulb Size: 3156LL
Front Side Marker Light Bulb Size: 916NA
Ash Tray Light Bulb Size: 161 or 194
Step/Courtesy Light Bulb Size: 168 or 906 or 912
Trunk/Cargo Area Light Bulb Size: 211-2 or 562
Under Hood Light Bulb Size: 906
Instrument-General Light Bulb Size: 194
Check Engine Indicator Light Bulb Size: 194
Hi-Beam Indicator Light Bulb Size: 194
Seat Belt Indicator Light Bulb Size: 194
Brake Warning Light Bulb Size: 194
Automatic Transmission Indicator Light Bulb Size: 194
Directional Signal Indicator Light Bulb Size: 194
Feb 17, 2010 | 2000 Mercury Mountaineer
My license plate lights are out...what kind of bulbs do i need??
Check this reference guide...
2002 Hyundai Accent Car Lightbulb Size Guide
Low Beam Headlight Bulb Size: 9003/HB2
High Beam Headlamp Light Bulb Size: 9003/HB2
Parking Light Bulb Size: 2357A
Front Turn Signal Light Bulb Size: 2357A
Rear Turn Signal Light Bulb Size: 1156
Tail Light Bulb Size: 1157
Stop Light Bulb Size: 1157
Back Up Light Bulb Size: 1156
Front Side Marker Light Bulb Size: 2357A
Rear Sidemarker Light Bulb Size: 168
Map Light Bulb Size: DE3175
Step/Courtesy Light Bulb Size: DE3022
From Sylvania Lamp Replacement Guide
License plate
168
168LL Long Life Upgrade: Up to twice the life of the standard lamp.
I hope help you with this. Good luck (remember rated this help).
Sep 09, 2009 | 2002 Hyundai Accent
Hampton bay Model 23758 replacement bulbs
go to any near home center (if there one). they should have the size bulb you need.
Home depot is authorized dealer form Hampton.
Oct 12, 2008 | Hampton Bay 24002 Ceiling Fan
How to replace headlight on a 2003 Chevy Tracker
There are two black plastic clips behind the the air filter, remove them and release the whole assembly to access the lights.
If you still get in troubles, have it replaced at a petrol station, they will help you in fitting the bulb, and it won't be expensive.
Here follows
2003 Chevrolet Tracker Light Bulb Size Chart
Parking Light Bulb Size: 1157A
Front Turn Signal Light Bulb Size: 1157A
Rear Turn Signal Light Bulb Size: 921
High Mount Stop Light Bulb Size: 168 Or 921
Ash Tray Light Bulb Size: 74
Trunk/Cargo Area Light Bulb Size: 168
Instrument-General Light Bulb Size: 158 or 74
Check Engine Indicator Light Bulb Size: 74
Hi-Beam Indicator Light Bulb Size: 74
Seat Belt Indicator Light Bulb Size: 74
Brake Warning Light Bulb Size: 74
Automatic Transmission Indicator Light Bulb Size: 74
Directional Signal Indicator Light Bulb Size: 74
Oct 02, 2008 | 2003 Chevrolet Tracker
Kitchen Appliances - Others Logo
231 people viewed this question
Top Nostalgia Electrics Kitchen Appliances - Others Experts
Anthony Ward
Anthony Ward
Sheldon Dedek
Gil Shultz
Are you a Nostalgia Electrics Kitchen Appliances - Other Expert? Answer questions, earn points and help others
