Health & Beauty Logo
Posted on Jul 23, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Proform Treadmill doesn't run constant speed.
I have a treadmill that is about 10 years old but has had low usage.
It runs but when you are on the belt it slows down then speeds back up.
When you are not on it it stays constatnt speed.
I have checked the potentiometer slide control and it measures resistance correctly.
I'm guessiing maybe its the motor but how do I know for sure?
Its a PROFROM 375 SI
  • alan93 Jul 23, 2008
    WHy isn't there a treadmill category on this thing????
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 05, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1051
Points
You have a friction problem between your belt and deck. A treadmill of this age either came with a waxed deck, or requires periodic silicone lubricant spray on the deck. You can check your owners manual to see which type of surface your machine has. Typical belt life on a consumer grade treadmill is about 2 to 3 years. If you purchase a new belt from the manufacturer it will come pre-lubricated.
Anonymous
Level 2:
  • Expert 304 Answers
  • Posted on Jul 25, 2008
Anonymous
Expert
Level 2:
Answers
304
Questions
Helped
148965
Points
750
Have you tried lubricating all the bearings and bushings? Oil the bushings on the motor shaft on both end if possible. Lubricate all the bushings or bearings in the rollers under the track also. Use a light oil like 10w 30. It sounds to me like the original lubricant dried out and is causing the resistance exactly what it should reduce. Get back to me and let me know how you make out. I hope this helps you out.
George
  • Treadm1ll Dec 16, 2010
    I just got a brand new treadmill and set it up 3 days ago. The speed fluctuates even when I'm not standing on the belt. I set it to 3 but it jumps to 6 and then 5 and whichever random speed. I think the machine came pre-oiled. Do I have a defective treadmill? Thanks!
970 Proform Treadmill Console
Run the software calibration, go under the HOOD cover motor, and see the instruction, for easy diagnostic and fix it. God bless yo
You must clean the speed sensor, and lube the elemation motor.
Proform 400 GI - Treadmill
go under the HOOD cover the instruction for RUN the software calibration for easy diagnostic , and fix it.
God bless you
Hello i have a proform crosswalk sport treadmill and when i turn the speed on it shows a reading for a couple of seconds, but doesn't come on. The incline works just fine. The motor will turn manu
adjust the REED switch see the diagram attached m clean it+test for open or faulty with DVOM, tight the connector very well,However try to RUN the software calibration and fix it. see the diagram attache too for speed sensor, adjust it and test it , clean it, and tight very well the connector.God bless you3_22_2013_4_18_58_pm.gif3_22_2013_4_19_19_pm.gif3_22_2013_4_19_33_pm.gif
Proform Treadmill 785 E suddenly stops during highs speed workout
Use 2000W converter instead of 750W because you are using your treadmill on its full power on high speed. 750W converter is not capable of handling its full load resulting the machine malfunctioning. Your treadmill 785E have 2.25 CHP motor, 2.25 CHP is equal to 1677.824712W and 20-Amp minimum Ac outlet is required for your treadmill in order to function in full capacity. Download user's manual on: https://www.sportsmith.net/images/product_support/ProForm/PFTL785081%20-%20PROFORM%20I%20SERIES%20785%20E%20TREADMILL/PFTL78508.1-274823.pdf See Horse Power to Watts Converter on: http://www.rapidtables.com/convert/power/hp-to-watt.htm
My proform 3.8 treadmill isn't running at the
see the diagram attached adjust the speed sensor, clean, and tight the connector very well.
2) Run after you did the adjustment the software calibration for diagnose, troubleshooting, and fix it.
sincerely. God bless you
Ifit treadmill stuck on highest incline
RUN inmedaitely the software calibration for diagnose, troubleshooting and fix it. Now that machine is running in slow speed.
sincerly. God bless you
1helpful
I have a model 297980 J8 proform treadmill. when I first start it up without the safety key in it, the treadmill runs at full speed for about 2 minuets. After that it slows down and stops. The speed is set...
You have to put the safety key in if you want to select speed/incline or predefined programs.
It starts and runs at full speed on that occasion because it's part of the maintenance process, that lubricates the inner rollers so that it will continue to work perfectly for as long as possible.
1helpful
2answers
Proform 765 EKG
If I understand correct, the treadmill will not run correct unless you have the safety key in. Well yes this is correct because once the safety key is removed the treadmill will stop. If your treadmill is running extremely fast just by turning it on, you may need a new speed sensor. www.AtlantaFitnessRepair.com
Top Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Health and Beauty Expert? Answer questions, earn points and help others
