SOURCE: problems with screen
No!dont even try to take it apart. Try the makers tech support warranty may get you fixed or even the store it came from
SOURCE: memory card error in powershot SD1100
Try a retailer near you to see if they will allow you to test your camera with a SD card from a display camera.
Good luck, I hope this helps!
Gom
SOURCE: Black screen problem with Canon PowerShot SD 750
Did you accidentally press the DISP button on the back of your camera? This manually turns the screen on and off to save batteries. Try pressing this button one more time to see if it turns the screen back on.
SOURCE: Need Canon Powershot SD1100 IS accessories
Battery and charger here http://astore.amazon.com/hubp0336-20/detail/B0017R6QGM
USB cable to transfer pictures to your laptop here http://cgi.ebay.com/USB-2-0-Data-Cable-for-Canon-Powershot-SD1000-SD1100-IS_W0QQitemZ390092684083QQcmdZViewItemQQptZCamera_Cables_Cords?hash=item5ad355fb33
Good luck!!
SOURCE: Computer Not Recognizing Canon PowerShot SD1100 IS Elph A
Depending on your OS, you can download the latest driver for your system directly from Canon here. Remember to select your OS in the dropdown tab to be able to see the available downloads.
But I'd also recommend that you take this as an opportunity to consider utilizing a much safer method of downloading your pictures and videos. Please see this link, as it describes the use of a USB card reader as a much easier, faster, and less error prone way to download your photos. Note that card readers are also VERY inexpensive these days (some places less than $2 online with shipping).
