Yes you can - but do not use the loudspeaker outlets on the rear panel.
There are a variety of outputs on the front panel (bottom right as you look at it).
You can use the main output, or monitor send - (for monitor you may need to use the relevant 'send' switches on each channel to send signal to these outputs.
You should also turn the power amp switch to main only (not main + monitor) so that the internal power amplifier is not connected to the monitor socket
You could also use the record out RCA (phono) sockets on the Peavey to connect to the CD / tape input on the main mixer.
You can download a pdf of the manual from here for more informationhttp://www.peavey-eu.com/index.php
Place your mixer in a location that will allow you to hear the sound coming from the speakers clearly. The best placement is opposite the speakers, centered between the left and right pair. Connect the power supply to your mixer.
Connect the female end of an XLR cable to a microphone. Run the other end of the cable to your mixing board. Plug the male end into the "Mic" port of an open channel. These channels provide the preamps that will shape the sound characteristics of the microphone signal, processing them for output. Repeat the process for each microphone in your rig
Connect one end of a balanced 1/4-inch cable to the left channel jack labeled "L" found on the "Main Out" panel. Connect another cable to the right channel jack with the "R" label. Connect the opposite end of each cable to the matching left and right inputs on you amplifier.
Power on your mixer and amplifier. Test each microphone connected to the mixer for output.
Adjust the volume of each microphone channel to create a balanced mix. Use the "EQ" knobs to shape the tone and cut out frequencies that are causing squeal and feedback.
