Question about Sanyo Xacti VPC-S60 Digital Camera
Lens error 1114
I was taking snaps, by mistake camera dropped from my hand. Immediately I took it up but the lens was struck i tried to off and on the camera but the massege is comming lens error 1114. Please help me out!!!!!!!!!!!!!!!!
  • 1 more comment
  • geedone Jul 28, 2008
    I have the Sanyo VPC-S750 and have the same error number. I do not want to send it to CA for repair (would cost more than camera is worth). So any ideas on what I could do???
  • Anonymous Aug 17, 2008
  • melbrett Nov 14, 2008
    lens error is showing up on screen of my daughters camera due to her possibilitie of a drop
    New Friend:
I have the help Yashika and do not know how to fix it help me !!!!!
Posted on Dec 12, 2009
Ok if your lans is kinda pointing to one side (like My) you cinda have to pray lol it worked for me love ya god and than you hit your lans to straitin it out and than it will turn on but tha lans still wont go back in so you have to hit it s cupple time down **** so it will go back but not hard dont hit it bck in just kinda lusint it a bit and than turn on the camera and it shuld taike in the lans.
hope i helped
Posted on Aug 05, 2008
    New Friend:
Open the camera, and then gently push the lens to the center, so that it is centered. Put the batteries in, and turn it on.. it should start as usual. Turn it off, and then put it back together.
Posted on Jun 06, 2010
6ya staff
SOURCE:
Camera Error # 45
If it is under warranty i advice you give it for service as this is a pretty complicated procedure to get it fixed.
E45 error message sometimes means that the lens is misaligned, This error is also may be due to failure of the control system.
To solve this:
You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. If none of these works then you can think of taking consensus with the service center.
You must keep in mind that to open the camera without good experience is not recommended and might tamper the delicate unit so best option is to Contact Kodak to see if your camera is still under warranty, otherwise contact any Kodak Cameras service provider, your problem will be solved.
Its very unlikely the lens is "out of alignment" this just cant happen unless its been dropped or bashed, in which case it may be broken.
Hope this helps. (remember to rate and comment this answer).
May 13, 2011 | Kodak EasyShare DX7630 Digital Camera
Tip
Sanyo digital camera showing lens error 1114 or 112
Hi.
If your Sanyo digital camera is not starting and you get lens error 112 or lens error 1114 prompted on display, that means that the lens is getting stuck, and cannot extend or retract fully. The controller board detects the error on startup, and shuts down after displaying the error message.
This errors usually happen because of dirt, or because the lens mechanis mis damaged in consequence of a shock.
If lens does not retract, try helping the lens back, without putting too much strenght, while you turn off the camera at he same time.
If the lens does not extend, try tapping softly the back of the camera to help lens out, while you turn off the camera at he same time.
If the camera had been exposed to sand or dust, try blowing canned air on the lens.
If this does not work, the lens assembly must be taken apart completely and re-assembed, and for that you need a camera repair shop.
Also call the number listed on the owners manual to get support from the manufacturer.
Check also the links below for more troubleshooting in case of lens error:
Lens not retracting on digital camera.
Lens Error.
on Apr 09, 2010 | Cameras
Dropped my sony digital DSC-W370 14.1 and the lens would not close. Have taken it to camera repair shops but they want to charge more than I payed for camera. Would like to know if I can try to close lens...
The lens error is due to failure of the lens control system. You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. If none of these works then you can think of taking consensus with the service center on a reasonable estimate as some of the costs are high and hence they charge more.If the get estimate is high then you decide to scrap and go for a new model.Since some of the spares are available only with Sony service, this must be thought of, as you do not have to run around for spares.
However if the camera works without the lens shutting try and use it without any repair as Sony would have estimated for lens mechanism assembly
Jan 20, 2011 | Sony Cyber-shot Dsc-w370 Camera
Lens error
get estimate before you decide. It will be good to have it checked at the Authorized service as you do not have to run around for spares.
If you arre able to open the camera , try and see if there is any mechanical jamming of the lens drive.
Jan 10, 2011 | Canon IXUS 82 IS Digital Camera
The lens cover will not open
The lens can become bound by grit and dirt, it can be off its tracks, or it can be sitting crooked due to dropping it or rough handling. First make sure you have a fully charged known good battery in the unit and it is turned off. Plug your Audio/Video cable into the camera. Lay the camera down on its back on a firm smooth surface. Press on the shutter button with one hand and while holding it down turn on the camera. If the lens becomes free, immediately point the lens down toward the floor and use the zoom to zoom it out. Take a soft brush, such as an art brush, and brush around the base of the lens to make sure you have removed any sand, dirt, etc. from the crevice around the lens where it enters the camera body.
If that doesn't free the lens there are a couple of other things you can attempt, but these may damage the camera too. If the camera is going to be tossed in the trash if it doesn't work try these two steps.
1. Take the battery out of the camera. Grasp the camera by the edges of the top and bottom with the lens facing downward. Cup your other hand slightly and smack the face of the camera into the palm of the cupped hand several times. Reinstall the battery and try the camera.
2. If step 1 didn't work, look closely at the lens seating in the camera. See if the gap around the lens is even all the way around. If it is not, take a thin tool or some sort that will fit into the gap at the narrowest point and softly pry the lens slowly toward the widest part of the gap. If the lens is off the pins, sometimes that will snap it back on. If you hear a small light snap. reinstall the battery and try the lens. If it works, point it face down and run the lens in and out several times using the zoom.
If this doesn't work, and again, only if the camera is going to be trashed if you can not fix it, try prying the the lens out forcefully, but gently. This has worked as a last resort many times. Good luck.
Mar 23, 2010 | GE A730 Digital Camera
EVERYTIME I TURN MY PHONE ON IT SAYS LENS ERROR. MY LENS IS CLEAN.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The lens can become bound by grit and dirt, it can be off its tracks, or it can be sitting crooked due to dropping it or rough handling. First make sure you have a fully charged known good battery in the unit and it is turned off. Plug your Audio/Video cable into the camera. Lay the camera down on its back on a firm smooth surface. Press on the shutter button with one hand and while holding it down turn on the camera. If the lens becomes free, immediately point the lens down toward the floor and use the zoom to zoom it out. Take a soft brush, such as an art brush, and brush around the base of the lens to make sure you have removed any sand, dirt, etc. from the crevice around the lens where it enters the camera body.
Mar 23, 2010 | General Electric A735 Digital Camera
Lens error 1114 on my camera
This is probably THE most common failure among digital cameras.
There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 07, 2010 | Medion 9653 Digital Camera
My Sanyo VPC S670 - digital camera lence is stuck
My camera had the same problem it would turn off after i tried to take a picture and it would say lens error 112 all i did was put duracell batteries in it as soon as i did it worked it seems wierd but try it its cheaper than getting a new camera
Jul 19, 2008 | Sanyo Xacti VPC-S60 Digital Camera
Sanyo Xacti VPC-S60 Digital Camera Logo
413 people viewed this question
Top Sanyo Cameras Experts
Paul Green
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
