1) Switch Off the UPS and unplug all Loads (like System, Monitor etc.) from UPS.
2) Switch Off the AC Power (Input Power to UPS).
3) Press the UPS Power Switch constantly unless you hear 2nd BEEP Tone. As soon as you are hearing 2nd BEEP Tone, Release the Power Switch.
4) This is COLD START of all APC UPS that will reset any internal problem.
5) If, however, the problem persists, contact APC.
Where u conect the power cable to the ups, next to it there should be a small removable panel or cover, inside there will be fuses check these fuses. replace blown fuses
SOURCE: 650 APC UPS
try to change with new battery and test. if it does't work it could be the hardware is malfuntion. but that the lastsolution to think, what are the indicator light is stated? can u descibe more detail on the ups. so i can able to asst u?
