1. Do not save any new file to memory card.
2. Connect your card to computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download recovery software, recommended one is this photo recovery (simply because i was using it and it worked)
http://www.asoftech.com/apr/
4. Install and open the photo recovery program, select your memory drive, and click 'Start' button to start scanning process which will find your deleted photos.
Step1. Stop using this memory card in case that any new file would
rewrite your original data and make it gone forever.
Step2. Insert this memory card to your computer and prepare to restore
your lost data.
Step3. Download a memory card data
recovery freeware to your computer and start to retrieve all your deleted
photos back:
http://www.freeware-fix.blogspot.com/2013/03/memory-card-recovery.html
In fact, this freeware has ever
successfully saved all the inaccessible data of my friend off from his camera.
So, I believe it can also work successfully on your phone memory card, too.
Simply read more information of this
freeware here:
http://www.freeware-fix.blogspot.com/2013/04/data-recovery.html
Step4. Save and back up all the restored photos on a different memory
card or drive in case of data recovery failure.
It is possible to recover formatted memory card only when you don't save any data to the formatted memory card. Because when you format memory card, the data remains there but the space it occupies is made available. So after the first format, you'll be able to carry out formatted memory card recovery with a near 100% success. But once new data is written to memory card, the chance of full memory card recovery will become less.
you can consider this article http://www.goshareware.com/resource/recover-formatted-memory-card.html
To restore memory card data from your corrupted or formatted memory card, you can fully depend on the Recover Memory Card software. Download the respective software and install it. This software spend very less time span to restore lost files successfully.
Sometimes what happens that the memory card gets corrupted due to some reason and leading to the files stored under it become inaccessible. In the situation like this, you can recover memory card files with the help of Memory Card Recovery software. A few days ago, I used this product to restore data from corrupted Nintendo Wii flash memory card. For more details visit the below mentioned website.
Hi, g_ramamohan_! If you want to recover your lost photos or videos from your memory card, this article could help you: http://www.best-computer-software.com/how-to/memory-card-photo-recovery.html Best wishes!
U can recover memory card via software "mmc full data recovery"u can find in google
