Hi
my Sony VPL-EX70 Projector is off
after on the projector and the sony slogan is up
after 5sec
the red lamp is blink
and the video
and the projector is stoooop
what i am no?
tankes
check ur projector fan sensor is ok one sensor is missing so short all fan sensor wire Its workcheck ur projector fan sensor is ok one sensor is missing so short all fan sensor wire Its work
You can't post conmments that contain an email address.
Take the lamp cover back off. Check the mechanism that the projector uses to sense the door. It might be a small pressure switch. Check whatever triggers the mechanisms is still attached to the door and hasn't broken off.
Hi, You can reset lamp timer of VPL-EX3 by following procedure. Connect power cord in wall socket, standby indicator will lit red. Press following keys on projector remote.. RESET, Left arrow, Right arrow, ENTER Lamp timer will reset. Hope this will help. Thanks.
hi, your projectors lamp cover may be open. or there is some thing happened (may be contact problem) with the lamp cover open sensing switch. just open the door and close it. and then try again. ok
I have solved this problem. Seems the rotating stand on the front bottom needed to be pushed and turned so that it inserts well inside. If it not well pushed the projector keeps shutting down itself every 10-15seconds. Took me about an hour to open the projector and doing all kinds of experiments to finally try that. :)
