The internal antenna on my Delphi xm2go doesn't work. It does fine with the home and auto antenna (which both plug in to the base of the unit via a dock. Is there a way to fine tune the build in antenna? The external "wearable" antenna doesn't pull in any signal either.
Don't use the wearable antenna - reputed to not work well - was not a good design idea - I don't think any of the other receivers have this feature if that tells you anything. Record music you like on the myXM feature, and play that when you would otherwise want to receive on the antenna. If you are listening to live news, etc, there may be no good solution. (I have read there is an antenna headset, but don't know much about it, but some reports that it works.)
