That model is a rear projection and the blue spot indicates failure of the LCD panel in the blue path on the optical block of the light engine. You can't buy the LCD panel only, and if you could you would not have access to the equipment needed to align and position it in just the right place, ie perform mechanical convergence... I'd say the unit probably not worth fixing.
