Just swaped cda9885 from my car to my truck, there was a cd in it when i switched vehicles. everything is fine with the sound and radio settings , but it will not allow me ti inset a cd. when cd is selected on the inputs it acts like it is ejecting a cd. also if you push gently it will eject the cd but again it wont let me pu one in. screen read error. ???
ALL THAT ANs NEVER SCANNED THE PCM ONCE.
TO SEE RADIO COMMUNICATION ERRORS ON THE NETWORK
yes this radio and all sub units run off the CAN_BUS network.
OR THE SAME ACT SHOWS RADIO, LICENSE CODE LOST.
MODERN CARS NOW EVEN PULLING THE MAIN 12V CAR BATTERY THE RADIO GOES DEAD. (OFFLINE) THE DAY1 NEW ARE THE GLOVE BOX IS OPENED
AND A TAG IS THERE, SAYS DO NOT LOSE THIS LICENSE. CODE
PUT IT IN A SAFE PLACE IT STATES.
THIS ANSWER IF FOR FACTORY oem CAR AND RADIOS.
or ask VOLVO for help, why skip that?
the service manual shows where are fuses reside
some cars have 3 fuse boxes
engine bay
cab
and trunk, <<< some cars with rear amps have fuse here too.
read the service manual and the matching radio page schematics.
wow 9 speakers and SUB woofer here.
ok have the SM on my screen , USA car. (vin)
scan it first and you did not.
f22, f28, f65/ f66/f67 fuse blown
R11B relay bad.
learn to use a scan tool and win.
stop guessing first.
scan it and see comm errors? oops.
does radio have head phone jacks to test for sound"?<< not sure me.
i would take back to the repair shop and tell them some one had tampered with the unit
had to reset station and push in your faceplate on radio but since they worked on car no sound from radio ... let them fix it or do what ever it takes to get you the anwsers to why it won't work to produce any sound...
sounds like you have the antenna remote wire (blue) instead of the amp remote wire (blue/white stripe) turning the amp on. the antenna remote turns off when the radio is switched to cd mode.
in any post - 2000 gm vehicle, the body body control module routes some signals through the radio., the door chimes and any warning sounds, etc. you need to buy a special adapter to retain these features, available anywhere that sells car audio.
what kind of vehicle do you have? i am going to guess your vehicle has a stock amp that it uses to power your speakers? you will have to hook up the remote wire for the amp to the wire that powers the amp in your vehicle (the stock amp) right now it seems like you have the "power antenna" wire hooked up to the stock amp in your vehicle.
Sounds like you're not getting voltage on the accessory power lead. This is the red wire at the back of the deck, and it supplies power whenever the key is switched on. It's possible that your vehicle's radio fuse is blown.
