From the description you gave on your post , sounds like you hooked the timer up correctly . Again , from the panel the hot ( black ) is jointed with the blacks feeding the inside switch and the timer correct ? And the Neutral ( white ) is jointed feeding the inside lights and timer for outside correct ? And from the timer ( GE model 15086 ) the Red Wire ( Switch Leg from timer ) is connected to the Black ( Switch Leg ) feeding the outside lights correct ? If this is exactly how you've wired your timer , then you have done your homework . Now all you need to do is make sure you have programed your timer correctly , and with your instructions that came with the timer , this should be no problem . If you continue to experience trouble , my suggestion would be to return the timer . It's not unheard of for some of these timers to come from the factory defective . This wiring configuration should not affect your inside lights . I hope this helps your home wiring project . I'm an electrician if that's any consolation !
Is there a white wire connected to the timer? It has to get power somehow to operate, so it probably needs a neutral. I'm guessing there is just enough of a leak through the ground that it operates at all.
