Hello, W/D here.
To install your strainer, you'll need some plumber's putty. The old one is removed by loosening the large ring on the underside and the strainer pulls out from the sink side. Once you are down to just the hole in the sink, you're ready to install the new strainer.
Get a portion of the plumber's putty in your hand about the size of a golf ball. divide it into two portions. Take one part, and roll it in between your hands, palms together and vertical, making a rope.
Take your rope, and place it around the sink hole. If you need more putty, roll the other portion in a similar fashion, and continue around the hole. You may need to overlap the rope putty where it's thin and at the ends to make sure that you get a good seal when you apply pressure the the basket. Place the strainer basket in the hole and press it down lightly, just enough to hold it in place. From under the sink, place the gaskets on the threads, followed by yjr large ring nut that will hold it all in place. Usually, there are two gaskets, a paper type, and a plastic type. Put the paper one on first, followed by the plastic, then the nut. Screw the nut down, applying some pressure to the strainer and plumber's putty. Adjust the strainer now, centering it in the depression in the bottom of the sink. Continue tightening the ring nut, pulling the strainer down into the sink, and squeezing the plumber's putty out, making a seal. Get it pretty snug, and wait a minute. The putty will continue to settle in the seal, and you will be able to tighten it some more after it does. Do this several times, and you'll end up with a good seal that will last. Take a regular screwdriver, and trace it around the strainer on the sink side to release the excess putty. You can ball it up, and press it back into the tub of putty, ready for the next time.
Best regards, --W/D--
