I need to know what mode is more conveniant
54g Auto
54g Performance
54g Only
54g LRS
802.11b Only
or better yet, what is the difference what are they for?
Greetings - Let's go over the settings in your router:
1) On the Home menu screen go to wireless in the left column
2) Wireless band should be setup as 802.11g
3) Mode should say access point
4) SSID should have a name - should also be the same name used on the laptop
5) SSID broadcast should be enabled
6) ***Important - For now set Authentication to open system. Make sure that is how your laptop WIFI card is setup. You can setup security after you get the two connected
7) Super G mode should be disabled
6) Move one tab on top over to advanced make sure data rate is auto
Try those settings (making sure the laptop settings match) and you should be able to get connected. If not, copy this text and return here and paste in into another request for help and someone will take you the rest of the way.
Good Luck,
Mikeywaf
I recently purchased a new wireless card for my desktop, it was a Linksys 54g with speedbooster but after the switch the networks I was connecting to (Free wireless from my apartments) will no longer connect. The old card that I had was just an offbrand card which used the microsoft zero connection tool to configure, this new card attemps to use the software included and ive tried to switch between the two different connection configuration tools both can detect the routers but when trying to connect it does not even get to the aquiring access key stage. the router is not passworded so I guess I was just wondering can this new card not connect to the router maybe due to brands? possibly the router is belkin or something of that sort and this linksys card cannot connect? I had before gotten it to connect at the very good 54kbps or whatever the number is but it would not let me access internet and then said limited/no connectivity. I also tried to change the settings on my wireless card and set them to 802.11b only, 54g auto, 54g LRS or Performance but all had the same result, I switched the default channel to match that of the router as well still nothing. dell inspiron 1525 battery
You can change the ISO setting also to Auto. If you have the advanced guide (see pp 80, 107).
Press the ISO button it will switch from various ISO setting to AUTO.
Do remember in Bright light , a lower ISO number like 80 will give you very fine images, while as the light level goes down, the ISO number will change to a higher number and the image will become more grainer.
I hope I could answer to your query.
Please do rate. Thanks
The 2801 (I used to have a 2803) is just an AV receiver, so it doesn't do any video processing.
If you get a DVD player with HDMI or DVI output, you'll be better off doing what you said - bypass the receiver for video and connecting the video directly to your TV, and the audio to your receiver.
It makes things less convenient since you can't switch inputs only with the receiver's remote, but you'll get a much better picture.
If you really need to control the whole system with a single remote, consider getting a Logitech Harmony remote or something similar. They're very convenient.
The range of 54g products is the same as 802.11b. They both operate in the same 2.4GHz frequency. Both 54g and 802.11b have better wireless range than 802.11a.
In some cases, older 802.11b clients may not be compatible with 54g wireless. These adapters tend to be of lesser design or use older drivers or technology. 54g-LRS (Limited Rate Support) allows these clients to be compatible with the newer 54g technology. Switching to this mode can solve problems that sometimes occur with these clients. If you suspect that you are using a client adapter that falls into this category of adapters, first check with the adapter vendor to see if there is a driver update. If there is no driver update available, switching to 54g-LRS mode may fix your problem. Please note that switching to 54g-LRS mode may decrease 54g performance. It is not recommended you use this mode unless you have a very specific reason to do so. This mode exists only to solve unique problems that may occur with some 802.11b client adapters and is NOT necessary for interoperability of 54g and 802.11b standards.
As with any wireless protocol, 54g has overhead associated with it that limits performance. While signaling data rates of up to 54 Mbps may be achieved, like most shared media (e.g. Ethernet) throughput will be significantly less. There are two scenarios for 54g performance. In an environment with only 54g clients, throughput can exceed 24 Mbps. This performance is equivalent to that of 802.11a, although 54g is usually available over a greater range. The second scenario is where 802.11b clients are present. RTS/CTS flow control must be used to allow 802.11b clients to recognize and establish communications with 802.11g access points. This leads to delays in transmission and drops peak throughput to about 10 Mbps. 54g performance is still well in excess of the maximum measured speeds of 4-5 Mbps for 802.11b. The use of RTS/CTS is important because it provides determinism to the wireless network, ensuring a minimum bandwidth for each user. Like Ethernet, 802.11 LANs normally use a ג?carrier sense media accessג? mechanism to signal transmission without asking for permission from the network. As the network becomes highly loaded, collisions occur more frequently and the network can become saturated with packet retransmission attempts that eventually make it impossible for any data to get through. RTS/CTS provides a more formalized flow-control mechanism that avoids this problem.
54g products will perform differently depending on whether or not there is 802.11b traffic in the immediate environment. The rules-of-thumb for throughput are: In an 802.11g-only environment, throughput will be between 4-5 times the throughput of an 802.11b network. The maximum throughput can exceed 24 Mbps. In an environment that includes 802.11b devices, throughput will be about double the throughput of an 802.11b network. The maximum throughput can exceed 10 Mbps. In addition, all 54g radios have better sensitivity than current 802.11b radios, and 54g provides outstanding coverage in its 802.11b compatible mode.
54g is Broadcom's maximum performance implementation of the draft specification for IEEE 802.11g wireless networks. This technology is expected to quickly become the next mainstream wireless LAN technology because it works faster and farther, is backward compatible with 802.11b and is affordable. Authorized products displaying the 54g logo use Broadcom's 54g wireless LAN chipset and ensures that products are designed to be completely interoperable at maximum performance with other 54g products and are compatible with the draft IEEE 802.11g specification.
