White pump gear on left side of printer mayhad come off .
First unplug printer power cord for 2 minutes and see if reset.
If the cartridges are fine it is a fault with the ink pump.
See if one of the following reset procedures apply:
1: turn on printer and wait to get ready
2: unplug powercord
3: press '6' and 'Select Photo'(most right of the '6') button and hold pressed
4: plug in powercord
5: keep holding key's pressed until display shuts down
6: release buttons; message "Semi NVM Reset"
2:
1: press simultaious "arrow left" + "arrow right"
2: enter '1 2 3'
3: this wil get you in to mfg menu
The reset is useful only if printer is jammed with error message, if there is a fault in the pump it won't fix it.
A common fault is the pump gear out of place, but you need to take apart the printer to fix this.
The update above works only on xp
If you have vista download from here
Let me know if you have problem installing the patch
I don't believe I've done anything other than that which the book said. Why the "fatal error" or IS it?
