Hello, check to make sure that the drain line is not blocked, this could cause the water to back up in the humidifier and leak, also make sure the water panel is clean and free of any mineral deposits.
I have the same drip problem. I cleaned the sediments and bought a new filter. I took off the hose from the unit and checked it -- it looks unclogged, then fastened it to the unit. The leak is still coming from the bottom of the unit. The drain line runs from the unit to the pump. I'll try changing the drain line. Thank you, Robert!
The water is completely off to the unit.
