Dynex 32 in. LCD Flat-Panel HDTV Logo
Posted on Feb 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Just bought an open box 32L152A-11. plugged in the electrical cord and inserted the input cable and screwed it in securely. fios box is not an "hd" so i am not i nserting a hdmi cable. i connected the red white and yellow cables i believe correctly and did try both options.
Anonymous
Level 2:
Sergeant:
  • Expert 214 Answers
  • Posted on Feb 09, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
214
Questions
0
Helped
101943
Points
560
From what i gather you are trying to get hdtv to work with rca cables without using an hdmi cable . if this is correct then all you need is RGB cables . just like rca but they red green and blue . look on the back side of your tv , there should be a set of RGB inputs and also rca .
Need help with what cables to use...
First make sure that both the monitor and the fios box have power cords (just to see if she took them away). If they do then the next step is will need a cable to hook your tv to your cable box. Most likely you were using an HDMI cable which on the ends of the cable have kind of a square head that is usually gold or silver in color. Then take one end and plug it into the fios box then the other into the tv. If there is no HDMI cable there might be a cable that has either 3 or 5 plugs on each end with certain colors. Just match the colors up on the box and the tv. If it is 3 plugs on each end then it is an av cable and that is the input you will have to select on the tv. 5 plugs and it is a composite cable and select that input. If it was the HDMI then choose that input. Hope this helps.
2answers
My husband bought me your DVD Recorder Model No. DMR-EH75V for Christmas in 2006. It worked with my analog TV and a COMCAST cable box. In April 2007, I bought an Olevia HD TV and changed to a Verizon...
Due to certain limitations of the Panasonic DMR-EH75V, it can only accommodate composite Video INput and give composite Video OUTput as well as the standard Audio L/R. Additionally, if your Verizon FIOS HD cable box has an RF OUT, that can also be connected to the RF/CABLE IN of the Panasonic.
Please refer to the simplified diagram below.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Changing the LCD lamps
You may follow the below mentioned steps to replace the lamps :
1. Power off the LCD TV. Unplug the AC power cord from the television and the electrical socket or power strip.
2. Locate the plastic or rubber grommets or screw hole covers on the rear edges of the LCD TV. Use an awl or small flat head screwdriver remove the rubber pieces from the screw holes by gently inserting the tool into the hole and prying out the cap. Note that on a few LCD TVs, the grommets or screw hole covers may be on the front face of the unit.
3. Loosen and remove the screws in the holes from which you removed the plastic or rubber grommets. Set the screws aside and keep them together.
4. Remove the plastic shield that protects the input ports on the rear of the TV if the unit has one. To remove the shield, use the awl to pry the plastic tabs loose or remove the retaining screws with the screwdriver.
5.Use the flat head screwdriver or awl to separate the front and rear pieces of the monitor casing. Start on the lower edge of the casing and gently pry the two pieces apart. Work your way around the outer edge of the television and separate the tabs until you can pull the front face off the casing. Remove the front bezel piece from the television.
6. Locate the inverter board below the LCD screen on the TV. The inverter board is small circuit board with wire connector plugs on either side. Disconnect the plug on the right side of the inverter board that leads to the backlight lamp bulb.
7. Use the Phillips screwdriver to remove the screws on the edges of the LCD screen that attach it to the rear part of the TV casing. After you remove all of the screws that secure the LCD screen, place the screen face down on a soft towel.
8. Remove the screws that secure the back light lamp in its track. If the wire leading from the back light lamp to the inverter board uses clamps or ties to secure the cable, disconnect or remove them. Remove the backlight lamp from the TV casing.
9. Insert the new backlight lamp into the track and secure with the retaining screws you removed from the old bulb assembly. Run the wire through the clamps or ties as needed to position the wire plug next to the inverter board.
10. Realign the LCD screen with the screw holes in the rear part of the TV casing. Insert the retaining screws and tighten them. Connect the wire plug from the back light lamp to the inverter board.
11. Replace the front part of the TV casing and snap into place. Reinsert the retaining screws in the holes on the rear of the TV and tighten with the Phillips screwdriver. Replace the plastic or rubber grommets and push them into place securely.
12. Reconnect the AC power cord and plug it into the wall socket. Power on the TV and use normally.
The prior owner of my house had verizon fios, the fios wiring is in basement as well as junction box for telephone (gray box) I have unplugged the ac power plug to the fios as I am not using their service....
you're better off calling verizon to remove it.
but no, it uses your power ... not anything from the street. fiber optic cable is made of glass and does not conduct electricity.
Hi, How can I replace the power cable of a kirby ? Thanks gs
You'll need three types of screwdrivers. A straight edge, and 2 Torx, sizes 15 and 20.
With the vacuum in an upright position, remove cord from holder. Use the #15 Torx to remove the two screws holding th cord to the vacuum. Use the #20 Torx to remove the screw where the cord enters the vacuum. Insert the flathead screwdriver into the slot on the left side of the "box" and release the tab. Gently pull on box at the top and tilt out. Unplug the old cord and plug in the new.
Reverse these instructions to put everthing back together.
Here's a video showing how it's done on the Sentria. It's the same on my G4, so should be the same for a G6. Excellent video with easy to follow instructions.
http://www.youtube.com/watch?v=rXZjv3mh280&playnext=1&list=PLAD4F1D2DB5A5C97A&index=11
I got a hd box and the channels keep cuttin out
Hello, I actually install HD boxes for Verizon Fios. If your video signal is too low, you will notice "Pixellation" (Those weird square boxes that come and go) and in some cases, you will not even be able to receive some channels at all. HD channels use much more bandwidth than standard definition channels. The good news....there's a fix. If you use standard cable (Not Fios) you can buy a signal booster. These can be purchased at best buy, Radio Shack, etc. It is a powered device that plugs into an outlet (110v) You take your cable company's input or "Feed" run it into the booster, connect the power, and the run a coax cable out of the booster and into your splitter. Assuming all of your cabling is up to par, this will fix your problem. If you have Verizon Fios, you must call and have us come out as our tv service uses "Moca" and cannot be boosted with a store bought unit. I hope this helps.
4helpful
2answers
How do you hook the four wire electric cable to the terminal marked L1, L2, L3? the wires are colored red, white, black and green.
To connect power cord:
• Remove the screws from the cover of the
junction box located at the top rear of the dryer.
• Loosen/remove the two screws on the strain
relief clamp and remove from 4-wire supply
cord.
• The strain relief splits into two indentical parts.
• Insert the large flange of both sections into the
hole located on the left side of the junction box
housing. The short flange of both sections and
screws must remain positioned on the external
side of the junction box housing.
• Insert the 4- wire supply cord through both
sections of the strain relief and re-install strain
relief screws, do not fully tighten until electrical
connections are complete.
• Attach the power cord ground conductor (green
wire) to the ground terminal marked with the
ground symbol. Tighten screw until ground
conductor is secure. (See Fig. 7)
• Attach the power cord neutral conductor (white
wire) to the neutral terminal. (marked N)
Tighten screw until neutral conductor is secure.
(See Fig. 7)
• Attach the power cord phase conductor (black
wire) to the phase terminal (marked L3).
Tighten screw until power conductor is secure.
(See Fig. 7)
• Attach the power cord phase conductor (red
wire) to the phase terminal (marked L1).
secure.(See Fig. 7)
• Tighten the screws on the strain relief so that
the power cord cannot be moved.
• Re-install the cover of the junction box and
secure with four screws removed earlier.
• The dryer is now ready to be connected to the
power supply receptacle.
This is from the manual for the Danby DCD5505W. You did not give the model # so I went off of what you listed it under.
Good Luck and please rate 4 thumbs for the free answer.
Now have verizon Fios and cannot get DVD player to play
Check the connection cable. If the Verizon box and the DVD player are connecting to the same TV input, ensure that the Verizon fios box is connecting to DVD input, and DVD output is connecting to TV.
If you connect DVD out to Verizon box input, and then TV , you will have to turn off the receiver box to see DVD.
If you use only one TV Input connect Verizon output to DVD input and DVD out to TV.
If instead you use separate inputs on TV, then try using the source/select input button on TV remote, and try different cables.
Regards.
KDL-32XBR6
Try resetting the TV by holding down the "up" button on the remote (with the TV powered on) and then, while you hold down the up button on the remote, hit the power button on the TV. This should do a "factory reset" which will wipe all settings in the TV. There is no reason why the TV should not "remember the last input it was on when it was ;last turned off. Also be sure that the TV is not plugged into a switched AC outlet, like the outlet on the back of the cable bix. The TV should be plugged into an output that receives power at all times.
2answers
VCR to TV
Your FIOS box is typically a Motorola Digital Cable Tuner. In order to record from the VCR your FISO will have control of the tuner, not the vcr. If your FIOS has two video outputs on it for video (av connections), one should be plugged into you tv set and the other should be plugged into the VCR input. Your cable tuner will have to be set for the channel you wish to record ahead of time while the VCR tuner has to be set to record the line input at whatever time you wish to record. If your FISO has one video output line (av connections), your VCR has to be set to channel 3 when you record (provided that is the channel your FISO box is set for when viewing TV over the coax cable) and you will have to attach the coaxial output from the FISO into the coax input of your VCR.
The only way around this is to get a splitter and split the coax line so that the FIOS is connected to the coax as it is now and the VCR is connected to a seperate line using the coax input, however using this configuration will prevent you from recording digital channels. If you have a cable ready VCR, it will probably only recognize channels up to 150.
If you really want to get it to record digital channels without the hassles find out if Verizon has a FISO box with DVR to it or connect a Tivo to your FISO. Tivo will tune the FSIO when it records and it's very user friendly to use.
Top Dynex Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Jesse Walters
Jesse Walters
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
