Question about 7752V Replacement Transmitter Supercode Remote for 5901 Responder LC3
How to program a 7752V VIPER REPLACEMENT REMOTE
  • 3 Answers
Open driver door.
Push and hold "f" key until remote beeps.
Push remote start button once so "pair" appears on screen. Push and hold "f" until remote beeps three(3) times to select pair mode.
Insert key into ignition an turn to "ON" position.
Push and release "valet" button on antenna, push again and hold until remote emits a series of beeps and displays "passed"
Posted on Jul 04, 2013
4 Suggested Answers
Anonymous
SOURCE:
ballistix234
  • 87 Answers
SOURCE: how do program a replacment two way remote for
If you go to the website then to the support page under guides, you can find your models manual which give you installation and reprogramming instructions.
Posted on Oct 26, 2009
Anonymous
  • 53 Answers
SOURCE: Viper 5701 remote programming
1st you need to enter the remote into progamming Hold the Function button until the remote gives a long beep and LED light comes on the remote a (it takes about 8 sec.) Then press and hold the remote start buttom until the remote beeps 3 times and LED lights up. Now your ready to program the remote
One of the door has to be open . Insert the key - turn the key to the On position then press the button on the antenna once and then press it again and hold it
You hear a chirp and then you press the lock button on the remote and then you hear a second chirp to recieve confirmation and then release the button and the turn off the key .
Remote should be program
Posted on Jul 12, 2009
alex
  • 132 Answers
SOURCE: how to program viper 5701 remote
Unlock doors
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in to IGN position
Push valet (black button) one time and release
Push and hold valet button
Push either lock or unlock on viper remote
Key out of IGN
Test unit
The horn or siren may sound afterwards to indicate SUCCESS!!!!!!
Posted on Apr 04, 2010
My sst 7752v viper remote will not unlock my doors, it just beeps. I cant get into my truck without my remote... please help
how old is the remote is a question to consider. the batteries might just be too low to send a strong enough signal for the truck's transponder to receive. does the remote need to be coded to the truck if not more than likely its weak batteries. the LCD display doesn't need much power to light up, but the remote does to send the signal.
Aug 08, 2013 | 7752V Replacement Transmitter Supercode...
I need a charger for 7752v remote
you can charge it from your computer if you have a mini usb cable like one from a camera would work. Also if you have an old cell phone charger that has the mini usb connector on the end will work. The motorola driod x charger would be a perfect match. If you need to replace the battery because the remote will not turn on any more I replace the batteries on ebay search viper 7752 remote battery service. Hopefully this helps.
Feb 05, 2013 | Viper Televison & Video
Remote 7752v dead wont start
I replace the batteries in the remotes search ebay viper 7752 remote battery replacement.
Dec 02, 2012 | Viper 7752V
Viper 7752v frozen
If the battery is dead there is a guy on ebay that replaces them. He fixed my remote.
Nov 01, 2012 | Viper 7752V
How to set viper 7752v remote on vibrate
Press and hold the "f" button the remote for approx. 8 seconds. The screen will display remote setup. Press the Aux button to scroll up and the remote starter button to scroll down. Press and hold the "f" button to enter the selected feature, which would be page alert. When the option you want is displayed on the LCD screen (vibe,tone,both,off) press and hold the "f' to save. You can press lock or unlock at anytime to exit the remote programming.
You can also press "f" then lock or unlock to silent arm or disarm without going through the above programming procedure.
Aug 20, 2012 | 7752V Replacement Transmitter Supercode...
Need viper 7752v owners manual
The 7752V remote is compatible with five Viper systems. The owners manuals for each respective system can be downloaded via the following links:
5904
4704
5501
5901
5704
Nov 15, 2011 | Remote Start System
I just received a brand new viper 7752v remote and it will not power on even when plugged into the charger. I have tried to press the function key several times to reset it and nothing. Any Suggestions?
Try plugging the charger into an outlet then, plug the charger into the remote, remove, plug in, remove...Do this for approximately six(6) times or, until "charge" appears on the remote. When "charge" appears on the remote leave it pug up to complete charge.
Jul 11, 2011 | 7752V Replacement Transmitter Supercode...
Will not charge
I have the viper rpn 7752v remote. I was away for a month and the remote completely died. I plugged it into the usb and nothing would happen. I called the installer and he told me a savvy trick. After plugging it into the usb, press the function button. Repeat this several times before it actually turns on. Repeated attempts eventually worked. He said even the manufacture doesn't know why this works. If you still need help you can email me and I'll refer you to a good installer. Tony@bostoninvestments.com. Tony Madan
Dec 10, 2010 | 7752V Replacement Transmitter Supercode...
7752V Replacement Transmitter Supercode Remote for 5901 Responder LC3 Logo
13,106 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Larry Tezekjian
Larry Tezekjian
david griffin
david griffin
Level 1 Expert
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
