You need a new latch assembly - go to attached link for part, pricing Search Over 2 1 Million Appliance Parts
SOURCE: dishwasher, flashing lights, frigidaire
The steam has gotten into the keypad display and fried it. Call Fridgidaire and let them know you've seen numerous people on the internet with the same problem and that you need part# 154554401 It worked for me.
SOURCE: Frigidaire Dishwasher - Spray Arm Not Working
When a dishwasher has been checked for obstructions in the sump area and the spray arms can spin easily (by hand) plus the spray arm holes are not blocked, you end up with either a broken impeller or a failing wash pump motor.
If you would like more details of have more questions, please post comment back here, OK?
Good Luck!
SOURCE: Frigidaire Ultraquiet III
I had the same problem with mine. I turned the heated dry off and it works fine.
SOURCE: Frigidaire dishwasher door squeaks when opened and closed
I had the same problem and this worked like a charm:
http://www.blog.applianceoutletservice.com/2008/12/frigidaire-dishwasher-door-squeaks.html
All you'll have to do is take off the kick plate, actually remove the cords, and lubricate with soap (lower tech than spray silicon, but it's worked so far...)
Testimonial: "Hey, thanks for the advice. Worked like a charm. Hopefully Frigidaire has improved their design."
SOURCE: Won't turn on. Frigidaire, precision wash, ultra quiet 1
I have the same issue and it occurred around the same time as your post. Do you think there is a conspiracy? :-)
You will need to get replacment parts...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
