Heating & Cooling Logo
Posted on Jul 22, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Noise I just bought the 8000 and 10000 BTU Frigidaire air conditioners just before my move and have found that they are very noisy (especially the 8000 BTU unit). The sound of the air flow is very noisy and the 8000 BTU unit also seems be have a slight irritating whining noise. I was thinking about taking out the three screws I saw on the side of the unit in hopes of getting the front off and attaching some cloth or something inside to make it quieter. Since I have now moved into New York City and am over 160 miles from where I bought them I cannot return them. Any ideas would be appreciated.
Anonymous
Level 2:
  • Expert 143 Answers
  • Posted on Jul 25, 2008
Anonymous
Expert
Level 2:
Answers
143
Questions
Helped
50730
Points
241
Adding cloth or any other sound absorbing material will not work. There is not enough room to add anything appreciable in the fan area.
My Frigidaire 12,000 BTU window air conditioner is tripping as soon as I plug it in!
did you clean it with water? They don't mix. Use a hairdryer to dry thoroughly.
Manual Available? BTU rating
Good Morning Friend,
I understand you are looking for the manual to your Frigidaire air conditioner, model# FAC084N7A. I also see you want to know the BTU rating. Your air conditioner is rated 800-BTU. I have attached the manual below. Hope this is helpful.
-Best Regards-
WP
Frigidaire Manual Search Results
How to Replace broken fan on frigidaire air conditioner FAL125M1A1
Most of these AC units that are small in BTU size, under 15k, can't be repaired because most manufacturers don't have replacement parts available. Contact Frigidaire first.
1helpful
Frigidaire FRA256ST2 window air conditioner unit quit working, breaker is fine and the plug reset only gets the unit to beep but not turn on
Have you recently plugged in another appliance (computer, microwave, etc)? The drain on your home's wiring system may not be allowing all appliances to run at once.
Some basic trouble-shooting guidelines can be found at: http://www.repairclinic.com/Air-Conditioner-Troubleshooting
Brand new (3 weeks old) 14K btu Frigidaire blows cold on and off. Serviceman came out (when it was working) and found nothing wrong. Are they just junk or what?
No sometimes the problem is intermint if it just three weeks old take it back for a new one. Dont wast your time for a service call, its cheaper ti repace.
We just bought a frigidaire 22000 btu unit. We we
If you have or know someone how has a multi meter just test that you have 220 volts at the outlet. Thats about the only way to tell. The fan will run if you only have 120v at the outlet, just not the compressor. so it will not cool. If you only 120v at the outlet it could be just a fuse or breaker problem. If it's a new outlet then it could be wiring wrong also.
Hope this help
Dan
4helpful
2answers
Water doens't drain properly and sitting there,
that's fairly common for window units, it's ok to drill a small hole in the underside of the case to drain the water, just be sure you don't puncture the condenser in the process.
2answers
Can a window air conditioner fit in an exhisting wall mount?
I bought window AC (5000 btu) that fit 17 in. at home depot. made by Zenith. Keep in mind of your room size.
Good luck.
Need to know the watts on a Fridaire Air Conditioner 6000 btu
check your name plate voltage and current rating, multiply it and the result is the wattage of the unit.
Top Frigidaire Heating & Cooling Experts
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
