Hello, W/D here.
Sorry it took so long to get back to you, the internet crashed, and I had to look at a few things, just to be sure.
It turns out that your oven lamp replacement is very close to an Advantium lamp replacement.
You have to remove the microwave from the wall cabinet, and remove the sheet metal surround. Then, you can access the bulb for replacement. The part # for the bulb is # 4375348 (whirlpool). These are available at Lowe's, H/Depot, or any appliance parts supply store.
I have an Advantium, and after two replacements, I cut a hole in the sheet metal, and fitted a metal "peep-hole" somewhat larger than I needed to get to the screws holding the bulb, and I screwed the cover plate down to the sheet metal. The result was that I wound up being able to slide the microwave out about 6" and change the bulb as opposed to having to remove the entire microwave from the cabinet holding it.
Hope that this is just what you needed.
Respectfully yours, --W/D--
Please feel free to rate this solution! Thanks.
