I'd check the thermostat for continuity first
Item 119 on this diagram
http://www.searspartsdirect.com/partsdirect/part-model/Electrolux-Parts/Range-Parts/Model-E36DF76EPS/1412/0122007/R0705157/00003?blt=06&prst=0&shdMod=E36DF76EPS
Hello Thecarsons, thank you for your post!
I understand that the lock light on your Electrolux range keeps flashing and everything else is working properly. This could be a potential problem with your latch or control panel. I would recommend looking over the latch or strike for any visible damage. If you do not see any, I would suggest performing a reset on your range. You can reset your range by disconnecting the power cord or flipping the household circuit off for at least ten minutes. If that does not resolve your problem you may need to have a technician out to your home to provide a proper diagnosis and repair. This will help you avoid any unnecessary part purchases. -Matt
