Question about Samsung HLR5067WX 50" Rear Projection HDTV
Green TV with lines through it
This morning my TV was working fine, but when I came home this afternoon to turn it on the screen showed green with lines running through it. The sound was running fine and you could vaguely see the TV show in the background. The other TV upstairs worked fine, so I am guessing the problem is with the TV. TV was working fine, but when I came home this afternoon to turn it on the screen showed green with lines running through it. The sound was running fine and you could vaguely see the TV show in the background. The other TV upstairs worked fine, so I am guessing the problem is with the TV.
  • 1 more comment
  • datscheff Jul 23, 2008
    When I went home yesterday I turned on the TV and again green screen. I unplugged the set for a few minuetes and then turned it on and the picture was clear and bright. What can cause this?
  • dea_007 Jul 29, 2008
    Our Samsung started having green lines on the screen or it will have green little squares all over the screen. The sound is fine, but the green squares/lines will still happen if we are playing a dvd. The weird thing is that when it initially turns on to the TV Guide list, it looks clear. We tried unplugging the TV and then waiting for a while, but the problem has persisted. Any suggestions??
  • Anonymous Sep 04, 2008
    I have the same problem. I was told by a tech that the digital board is bad and it will cost about $700.00 to fix. You can have them rebuilt for $290.00, but you will have to remove them yourself and send it to the service center. Google the part number and rebuild and you will find the company that does this service. I need to know what it looks like and how to get it out.
    New Friend:
  • 28 Answers
Replace DMD pcb
Posted on Jul 02, 2010
6ya staff
SOURCE:
Blank screen when wii is on
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
aqrtyctr-108
May 26, 2009 | Nintendo Wii Console
Green horizontal lines on screen no picture
The green CRT's (color picutre tube or color wheel, or ballast) will need to be tested for replacement.
It is quite common with these tv's
You will need an ohmmeter and or voltmeter and test each component for currency and accuracy
May 06, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Xbox 360 is showing purple lines on tv screen.
Hi...
Pull out the video cable from both ends.
Re-attach and try again
Let me know
Jan 18, 2009 | Microsoft Xbox 360 Console
Mitsubishi wd52525 problems
i have thought about this since you first posted it. if the demo is good then the light engine is ok. it sounds like a problem in the chassis. probably on the DM and the terminal board. to repair the chassis would cost about $250.00 plus shipping.
go to www.tv-techs.com
Oct 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi wd 52525 Problems, but no blinking lights.
Are you using an hdmi cord or av cables?
Apr 10, 2017 | Televison & Video
Green Screen/Shut off
Turn off tv for few hours and then turn on..
Aug 28, 2008 | Insignia IS 20" TV040919 TV
require model number of unit and how often this happends
Jul 16, 2008 | Samsung DLP HL-P5663W 56" TV
Shut-Off Problems with Philips 28ps6515/05
Green Screen with some lines lines are called retrace lines. it is due to maybe dry soldered or no green drive signal. This problem can be fixed by complete soldering in crt board. 1 green video supply absent 2 loose contact in green skt in crt board 3 crt board loose 4 no green drive signal.
Sep 15, 2007 | Philips 32PT6441/37 32" TV
Problems with green convergence
Very common problem John with projection sets. They have High powered audio amps inside the sets to control the red,green, and blue convergence for the color alighnment on the screen. These amps blow out and should be replace all at one time. There are also resistors that can go out at the same time and your gonna have to have these replace also if they have any discoloration to them. This is not a job for the novice to attempt, as there are HI Voltage safety issues involved, and should be done by a trained tech. This repair should run you anywhere from $250.00 all the way up to $400.00 bucks, depending on where you live and who you get to repair the set. It's always better, in my opiniuon to call a factory authourized repair place as they should have all the service data and most parts for your set. Good Luck
Jul 23, 2006 | Panasonic PT-53TW53 53" Rear Projection...
Samsung HLR5067WX 50" Rear Projection HDTV Logo
128 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
