The E7 fault code is telling you the electronic range control (ERC) is detecting a problem with one or more key on the touchpad. This fault code can be caused by a defective touchpad or the ERC. To determine which part is bad you need a technician to test the touchpad with an ohm meter. If the touchpad is good the ERC will need to be replaced.
