Epson Master
- Posted on Feb 07, 2011
Re: Bought new cartridged, replaced the old one but the...
Check the control panel for error indicators.
The error light is to the left of the display and is marked "Error," it
will illuminate. The error will appear on the screen and is in plain
English, so very simple to interpret. An example is "Color or Black Ink
Out," meaning there's no ink.
Verify that the Epson Stylus CX3200 is connected to the
printer with a cable. Try connecting without a USB hub while
troubleshooting---that way you can identify if the problem is with the
hub or printer. Replace the cable, it may be bad.
Print a nozzle check pattern to determine the extent of the
problem. The nozzle check will allow you to determine whether the
printer will print at all, and the results will give you a good
indication of print problems. Press the Menu button on the Control Panel
until you see Nozzle Check and press the Color Copy button.
Replace the printer cartridges if the Control Panel suggests
you do so. Press the Menu button until you see "Change Cartridge" Press
the Color Copy button and the cartridges will move to their change
position. Lift the scanner and unclamp the cartridge. Replace the
cartridge---color is on the right and black on the left. The Epson
Stylus CX3200 will start charging the cartridge and after about thirty
seconds the printer will be ready for use.
